nzae86's TRD ae86 N2 Race Car Project 2,
01-16-2010, 04:19 AM
Post: #271
Finally a little more progress! must be getting closer to start up soon !!
Shift light and brake bias fitted
[Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,]
I can now start the wiring as I have the center console made to mount the switches .
Just need to make up some mounts to take the fuse block and relays .
Your addiction to motorsport can only be cured by poverty !!
01-16-2010, 06:20 AM
Post: #272
Mounts made for fuse block and relays , now for the wiring
01-22-2010, 11:55 PM
Post: #273
Epic! Thumbs up!
Haaatschi! - Gesundheit!
01-27-2010, 01:38 AM
Post: #274
This car is mind blowing! I followed a link to this project and couldnt believe how well this car was being built, I nearly fell over when I realised its being built here in NZ!! I cant wait to see this car in action, and hear that engine. Great work, you bloody rock!!
01-27-2010, 01:47 AM
Post: #275
Mega congrats on what you acomplished there!
Super build, and awesome replica! Respect! Respect! Respect!
01-27-2010, 05:49 PM
Post: #276
Can't wait to see how the carbon door trims turn out. Should be much nicer than just flat sheet. Thumbs up!
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
01-28-2010, 05:46 AM
Post: #277
Awesome car anyways.. Respect! Pure automotive p0rn! Yummie!
Isn't it pretty hard to pull of heel 'n toe on that setup? If I'd had to twist my ankle that much it wouldn't make me smile. I don't even think it's possible?
01-28-2010, 09:38 AM
Post: #278
Lew Wrote:Awesome car anyways.. Respect! Pure automotive p0rn! Yummie!
If you were wondering the loud pedal has not been finished yet!
cheers
Have started on the brakes and will have the same size rotors front and rear,
And yes they fit in a 13" wheel with a 4 pot caliper
01-28-2010, 09:53 AM
Post: #279
Are you running TRD recommended cam timing or do you plan to play with cams on the dyno?
Are you moving to EFI after the carbs are set up?
The new TRD N2 car runs different0EFI and lower duration cams.
296/10.6mm IIRC. Spotted it on a youtube clip.
May be of interest to you.
http://www.youtube.com/watch?v=kf4LEb5ybHg
At 11:51 into the clip it shows the TRD N2 spec.
power: 220ps
rpm: 8800
cams: TRD special 296/296
weight: 854kg
Thought that might be of interest to you ;D
01-28-2010, 10:12 AM
Post: #280
irishtwincam Wrote:Are you running TRD recommended cam timing or do you plan to play with cams on the dyno?
power: 220ps
rpm: 8800
weight: 854kg
Hi there
I am planing to dyno the car and see what works the best , alot of factors need to be worked through , the engine I have was originally designed to run carbs , but I changed part way through my build and have decided to run EFI after the engine was built. Whether this is a good move or not will be known when I finally run the thing. I imagine a lot of time and expense is coming up to get the most out of the tuning.
From what I understand the early Atlantic cars ran carbs and had no rev limit, later on in the series the rules changed to injection with a 9500 rpm limit .
Cheers for the info
  nzae86's AE86 Levin Tarmac rally car build Project 1 nzae86 30 69,325 04-30-2013 07:28 AM
Last Post: nzae86
  my celica race car with race beams Celica RA45 14 26,926 09-14-2011 11:50 AM
Last Post: Celica RA45
  AKR's Daily-driver-race-car asian knight rider 5 13,550 11-01-2009 12:25 AM
Last Post: doggy
  My Project car :D Muchomuchacho 5 9,320 06-05-2008 05:15 PM
Last Post: Muchomuchacho
  A.D.D Performance Demo car (AE86 project) cab32 15 23,302 03-24-2008 03:34 PM
Last Post: cab32
