nzae86's TRD ae86 N2 Race Car Project 2,
09-27-2009, 06:35 AM
Post: #221
porn!!
09-27-2009, 07:39 AM
Post: #222
oooooooh caaaarbon....
I like it
A LOT!
TokyoSeven
For all your performance needs : Japan Direct!
Web: www.TokyoSeven.com
FaceBook: http://www.facebook.com/tokyo.seven?ref=profile
AE86 ADDICT!
[Image: AEU86 AE86 - nzae86's TRD ae86 N2 Race Car  Project 2,]
09-27-2009, 10:05 AM
Post: #223
dazed_driver Wrote:Nice dash/seat/belts/airbox. Oh, and the stack. I really want one... Sad haha
What are the dimensions on that airbox, if you don't mind? It would be nice to get the length, width at the back, front, height, and the diameter of the inlet. Thanks!
Hi there
The dimensions of the air box are
Length = 400mm
Height = 180mm
Width = 140mm
Hope this is of some help
Your addiction to motorsport can only be cured by poverty !!
09-27-2009, 10:13 AM
Post: #224
mc68 Wrote:mate, got a part# or model for the blower you used for the demister? was a cut of ally used to get it to fit onto the heaterbox?
This blower is a TMC brand and its air flow is 122CFM , I just went to the local marine shop and purchased this as a bilge blower for use in a boat.The old heater box I gutted everything out of it and made new baffles inside it to direct the air through the heater core ,and only out the top to the windscreen .Then used some aluminum to make a plate for the end and mounted the blower to it.The intake for it is through a plastic bend and draws air from outside through the original place under the dash.
Hope this is useful !
09-27-2009, 01:01 PM
Post: #225
very very helpful, thankyou!
Brake with the left hand, steer with the right foot...
09-27-2009, 10:38 PM
Post: #226
why do you use a airbox ?
http://bruutt.blogspot.nl/
09-29-2009, 11:31 AM
Post: #227
einneb Wrote:why do you use a airbox ?
By using an air box you can draw cold air away from the engine and with the filter further away from the end of the throttle bodies there is no interference with the air speed and flow.
09-29-2009, 02:10 PM
Post: #228
ah oke Smile
10-01-2009, 06:22 AM
Post: #229
Today the final hole in the body shell was filled with a new laminated windscreen, also another interesting discovery made as well . I lot of people here have had trouble getting a new replacement screen for these cars as the new ones all appear to be too short .Toyota have made two different scuttle panels that fit under the windscreen , one fits the original toughened glass screens from the factory and the other fits the cars that left the factory with a laminated screen that is shorter in height .All that can be purchased here in NZ is a laminated screen .
Here is a photo of the two different panels
Well you learn something everyday!
Nice and shiny!!
Managed to get a bit of work done on fitting the dash in and fitting up the center console, this takes the reservoirs for the master cylinders on the pedal box , also it will give me something to mount the fuse boxes and relays to as well
so the inside is starting to come together finally .
10-01-2009, 04:37 PM
Post: #230
I noticed that on my windscreen too when I replaced it due to a chip/crack, although the laminated screen I took out wasn't original either. I should have ordered the shorter panel when I got new sides and top trims... but the longer panel is ok (If it was short panel short screen then Confused )
I maybe would have mounted the remote reservoirs on the firewall behind the dash just to keep the interior less congested... but makes for easy access and keep fluid levels in check.
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
  nzae86's AE86 Levin Tarmac rally car build Project 1 nzae86 30 66,393 04-30-2013 07:28 AM
Last Post: nzae86
  my celica race car with race beams Celica RA45 14 25,347 09-14-2011 11:50 AM
Last Post: Celica RA45
  AKR's Daily-driver-race-car asian knight rider 5 12,752 11-01-2009 12:25 AM
Last Post: doggy
  My Project car :D Muchomuchacho 5 8,561 06-05-2008 05:15 PM
Last Post: Muchomuchacho
  A.D.D Performance Demo car (AE86 project) cab32 15 21,830 03-24-2008 03:34 PM
Last Post: cab32
