mass air flow sensor mod?
06-17-2008, 09:23 AM
Anyone know where I could fine a step by step guide for this mod?
thanks
06-17-2008, 05:22 PM
Skeptical Wrote:Anyone know where I could fine a step by step guide for this mod?
thanks
Kind of a useless mod.
No power gains, more gas usage...
Why do you want to do this?
Andrew
06-17-2008, 06:07 PM
just heard it was a good mod to do on the car. Since I'm still trying to figure out things on my car I didn't know whether it would be ok to do.
06-17-2008, 06:36 PM
Nah, waste of time & will only lead to the car not running right.
Your time and effort would be better spent getting the car reliable. IE: doing maintenence (sparkplugs/cap/rotor, changing all fluids, ect.) and perhaps replacing all the blown suspension bushings.
Andrew
06-17-2008, 10:44 PM
oh ok, thanks for replying tho. Currently using a fwd distributor cap on my car as well as ngk wires.
another question I have is; how to know if I have a high or low compression motor? Do I have to take it apart to find out?
07-06-2008, 02:44 AM
So true, unless you design a circuit to modulate the signal correctly.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Air conditioning R134A swap sheppardpat47 7 2,491 10-13-2026 10:21 AM
Last Post: seefuchs
Big Grin map sensor cheating? fdsjakl890 8 4,274 08-26-2025 01:12 PM
  Fitting Air Con (No PS) to LHD AE86 pack 7 8,548 01-07-2024 11:36 AM
Last Post: CCB
  Lambda sensor wiring sam3007 10 9,785 05-23-2022 10:00 PM
Last Post: The Doctor
  Air Cleaner Assembly Hama86 7 13,095 10-29-2018 03:28 AM
Last Post: Hama86
