japanese headers
11-21-2008, 09:28 PM
Post: #31
japanese headers
price for RS*R?
go-go-go!
11-22-2008, 12:15 PM
Post: #32
japanese headers
Here's one more header that's designed exclusively for LHD cars;
http://www.martelius.com/index.php?modul...uct=490045
I have the previous "evolution" Martelius header for AE86, which is 4-1. Fits right in without any problems but stiffer engine mounts (f.ex. TRD ones) are required as the tubes pass _very_ close to the frame rail on their way down.
11-22-2008, 12:42 PM
Post: #33
japanese headers
http://img357.imageshack.us/img357/9261/cimg6612gr7.jpg
as you can see it's been modified to fit in lhd car but you still need to flange it 1cm or so...I would ask 150
for like 20.000 yen I would buy a used header in japan at specialized shops but I have to be sure it fits, anybody knows any model?
11-22-2008, 05:25 PM
Post: #34
japanese headers
the whole idea is to keep the tube diameter same throughout the whole lenght. You've just changed that.
Philip
11-22-2008, 06:26 PM
Post: #35
japanese headers
Hmmmmmm does anyone else see the Martelius 4/2/1 does NOT alternate on the primaries??? 1-3-4-2 shouldn't pipes 1 and 4 be grouped together and and 3 and 2 grouped together???? That way the pulses are even when they arrive at the next joint.
There is SOME work going on now in the USA for a LHD header. Here is the current link - http://www.hachiroku.net/forums/showthread.php?t=14855
A few years back(3 now...) I was able to resurrect the old Dobi/KBD header.
[Image: AEU86 AE86 - japanese headers]
We sold about 75 of them... and rarely is one for sale used..... fit was very good with the only issue being the EGR pipe had to be loosened at the compression fitting to make proper fitment. No bending.... just looseneing and then tightening once all were aligned and fitted.
No modifing of the car at all! Noo excess heat(w ceramic coating). The most common comment... this header smooths out the 4AGE......
Externally measured
Primaries - 38mm(1.5") x 406mm(16")
Secondaries - 45mm(1.8") x 406mm(16")
Collector - 66mm(2.6") x 102mm(4")
Adapter - 66mm-52mm x 255mm(10") the "stock" adapter allows the header to bolt to the stock cat...
OR a custom adapter can be fitted if you choose to run 2.5" exhaust
Dan -
11-22-2008, 06:58 PM
Post: #36
japanese headers
hi Dan,
Thanks for the link Thumbs up!
Philip
11-22-2008, 07:25 PM
Post: #37
japanese headers
oldeskewltoy Wrote:Hmmmmmm does anyone else see the Martelius 4/2/1 does NOT alternate on the primaries??? 1-3-4-2 shouldn't pipes 1 and 4 be grouped together and and 3 and 2 grouped together???? That way the pulses are even when they arrive at the next joint.
Quite interesting - I hadn't noticed that before.
Grouping cylinders only 180 degrees apart like on the Martelius header is going to move up the RPM range at which the scavenging effect of the exhaust pulses creates a benefit. So the pulse from #2 is going to scavenge exhaust from #1 and #3 from #4 - the engine just needs to run at a high enough RPM for the effect to occur. The long secondaries are probably tuned so that the pulses from #1/#2 and #3/#4 interlace to create a scavenging effect to #2 and #3.
Designing exhaust headers is really a strange artform and I'm not very very good at understanding how it all works but I'd imagine that the Martelius header works similarly to a 4-1 (peak power at quite high RPM) but with the additional benefit of an extended torque range of a 4-2-1 design.
11-22-2008, 07:57 PM
Post: #38
japanese headers
robotype you have P.M.
go-go-go!
11-22-2008, 08:25 PM
Post: #39
japanese headers
@firehawk, the Martelius header you've got is a 4-1, you told. How is it performing? In which powerband does this header unleash its performance?
02-21-2009, 01:15 AM
Post: #40
japanese headers
OFFICIAL Group Buy: Custom Hytech Headers
http://www.aeu86.org/viewtopic/official-...ers/t/8291
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 25,043 05-01-2021 10:09 PM
  Headers recognition FanIsHere 2 4,457 11-23-2020 02:28 PM
Last Post: FanIsHere
  European/UK vs Japanese Levin "Glass Grill" mad.matt 3 7,706 10-20-2017 02:47 PM
Wink LHD AE86 headers and exhaust Lt86 54 78,901 05-25-2017 06:13 PM
Last Post: zenki
  How much performance gain from headers ?? jondee86 28 36,151 02-21-2009 01:14 AM
Last Post: gx9901
