ignition timing problem
03-07-2007, 12:05 AM
I 've just finished my engine rebuild and I have some ignition timing problem .
I've fixed new Catcams camshafts (260°/256°) with adjustable cam gears . Both IN and EX cams are well timed (110° both , from TDC). The distributor is well set( two marks aligned). Yellow connector is shunted . At idle , timing advance is at -(minus)5° (5° below tdc).That engine needs 10° at idle .... The adjustment is at max . With the engine reving at 4800rpm , I have 29° timing advance . I found the engine very slow , below 5000rpm, but much better at high revs. Any help welcome Filh Filh Save the RWD cars |
03-07-2007, 12:11 AM
Double check if the cams are not turned "180 angle off" cam wheels.
This is not joke. |
03-07-2007, 06:17 PM
First check jamie´s remark, then have another look at the distributor alignment, it may just be a tooth off, wouldnt surprise me since the drive gear on the new cams might be slightly different from stock.
03-07-2007, 11:26 PM
hello,
Cam gears ok , well in place .Moving with one teeth before or after the stock distributor mark makes no solution.... the engine doesn't start! still searching..... thanks for suggestions filh Filh Save the RWD cars |
03-08-2007, 12:02 AM
did you put all the ground wiring?
Try to put the cams with stock alignment, and, its allways good to check again if the timing belt its ok. ![]() Cump´s Filipe Oliveira |
03-08-2007, 12:45 AM
Are you sure you have the right settings for dialing in your cams ???
AE86 FANATIC!!! |
03-10-2007, 12:52 AM
yes , all ground wires are connected .
I'm sure about cams setting (both 110° from TDC) . I've found a solution , by clocking the distributor a little and drilled the distributor "ears" fixing . But it's still remaining mistery to have lost that 10° timing advance at idle . I think , as it was sais that all that come from the Catcams product . Will be soon fixed about reliability , as I'm rallying this week-end in Belgium (rallye de Hannut , small city between Liège and Bruxelles) filh Filh Save the RWD cars |
05-14-2007, 06:45 PM
I got similar problem with the advance. It did not move nowhere from 20 degrees of advance even if service connections were attached. All grounds were good but i have painted the engine room and the coil did not get ground by its fixing bolts any more.
05-14-2007, 10:01 PM
thanks , but i didn't move the coil .
I'm now riding with advance tuned by .....ears and it looks ok filh Filh Save the RWD cars |
| Ignition switch plug and wires | Blaze0010 | 3 | 2,979 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 17,483 |
| 4agze timing | leon205gti | 11 | 17,872 |
04-07-2017 03:10 AM Last Post: jondee86 |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 6,997 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 11,937 |
![AEU86 AE86 - ignition timing problem [Image: AEU86 AE86 - ignition timing problem]](http://lipinhu.no.sapo.pt/sbanner.jpg)
