hi, guys How i can Setup Factory Time 4AG 24+1 ignition
04-12-2011, 03:01 PM
hi, guys where i can find information about how i can setup the stock ignition timing on 4AGE using a Distribuitor 24+1
for example in the wheel 24 how i can identified the tooth #1 this is for a MegaSquirt II setup using V6 Camry Coil on Plug thansk for your time and help guys. http://www.ae86rd.com |
04-12-2011, 03:27 PM
The one that's missing!
04-12-2011, 03:52 PM
heheheh but in the 24+1 i not see the meesing tooth :..( this no have a signal or somenthing ?
04-12-2011, 06:32 PM
![]() think you should look for something like this ? '87 levin coupé |
04-13-2011, 07:36 AM
On the OEM 24+1 there is no missing tooth. The missing tooth is represented by the 1 totth in the dizzy. The OEM ECU combines the 24t and the 1t signal to calculate where the engine is at.
Don't no nothing about MS, I'm more a Haltech guy. But I saw people grinding one tooth out of the 24teeth wheel http://monkeymagic86.wordpress.com |
08-03-2011, 12:36 AM
Nomuken PLZ i need some help. I have 4agte 16v engine, haltech 1000 and 4 ls1 coils. Whats the best for ignition timing?
08-05-2011, 10:52 PM
CHACAMAN Wrote:hi, guys where i can find information about how i can setup the stock I´m thinking you should be poking around in here.... http://forums.club4ag.com/zerothread?id=11048 Cheers... jondee86 |
| Coil charge time | totta Crolla | 0 | 243 |
01-23-2026 07:27 AM Last Post: totta Crolla |
| Can Wing Mirror Glass be Replaced? | chrisae86 | 4 | 3,005 |
10-05-2025 11:09 PM Last Post: chrisae86 |
| Ignition switch plug and wires | Blaze0010 | 3 | 2,732 |
| Question about 4AG 20v Engine Block | CHACAMAN | 1 | 2,901 |
| Can you convert your 86 back too the original state? | gh0st | 7 | 5,499 |
![AEU86 AE86 - hi, guys How i can Setup Fa...1 ignition [Image: AEU86 AE86 - hi, guys How i can Setup Fa...1 ignition]](http://www.enjukuracing.com/images/trigger_wheel_1.jpg)
