hi, guys How i can Setup Factory Time 4AG 24+1 ignition
04-12-2011, 03:01 PM
hi, guys where i can find information about how i can setup the stock ignition timing on 4AGE using a Distribuitor 24+1
for example in the wheel 24 how i can identified the tooth #1
this is for a MegaSquirt II setup using V6 Camry Coil on Plug
thansk for your time and help guys.
http://www.ae86rd.com
04-12-2011, 03:27 PM
The one that's missing! Smile
04-12-2011, 03:52 PM
heheheh but in the 24+1 i not see the meesing tooth :..( this no have a signal or somenthing ?
04-12-2011, 06:32 PM
[Image: AEU86 AE86 - hi, guys How i can Setup Fa...1 ignition]
think you should look for something like this ?
'87 levin coupé
04-13-2011, 07:36 AM
On the OEM 24+1 there is no missing tooth. The missing tooth is represented by the 1 totth in the dizzy. The OEM ECU combines the 24t and the 1t signal to calculate where the engine is at.
Don't no nothing about MS, I'm more a Haltech guy. But I saw people grinding one tooth out of the 24teeth wheel
http://monkeymagic86.wordpress.com
08-03-2011, 12:36 AM
Nomuken PLZ i need some help. I have 4agte 16v engine, haltech 1000 and 4 ls1 coils. Whats the best for ignition timing?
08-05-2011, 10:52 PM
CHACAMAN Wrote:hi, guys where i can find information about how i can setup the stock
I´m thinking you should be poking around in here....
http://forums.club4ag.com/zerothread?id=11048
Cheers... jondee86
  Coil charge time totta Crolla 0 103 01-23-2026 07:27 AM
Last Post: totta Crolla
Wink Can Wing Mirror Glass be Replaced? chrisae86 4 2,854 10-05-2025 11:09 PM
Last Post: chrisae86
  Ignition switch plug and wires Blaze0010 3 2,461 11-25-2024 12:29 PM
Last Post: Blaze0010
  Question about 4AG 20v Engine Block CHACAMAN 1 2,796 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Can you convert your 86 back too the original state? gh0st 7 5,309 04-25-2022 04:25 PM
Last Post: gh0st
