fender holes measure HELP
12-22-2010, 07:14 AM
hi guys
hope an ae86 fan could help me with this issue
very simple indee
can someone please measure the holes center to center or measure between nuts
here is a pic[img name=]http://www.aeu86.org/files/tr/troubelfender_ae86_650.jpg[/img]
++if you have the fender out just do the measure from the center as the pic
or if you have it on the car,just do the measure on top and on the center of the nut
++I think is very important not have had a crash cause maybe that can vary the measure
what do you think?
but most important for me is the measures
A=?
B=?
C=?
D=?
E=?
F=?
i think the other fender MUST have the same measures right cause in mine doesnt
cheers guys
HELP!!! Sad
p.s
OFcourse more than 1 opinion and member help will be really apretiate it.
[Image: AEU86 AE86 - fender holes measure HELP]
12-23-2010, 05:44 PM
sergiocharged Wrote:hi guys
very simple indee
what do you think?
A=?
B=?
C=?
D=?
E=?
F=?
cheers guys
HELP!!! Sad
p.s
oh boy Confused
12-23-2010, 07:33 PM
i'm going to take those meassurements you need after x-mas
12-23-2010, 09:38 PM
A= 60
B=115
C=175
D=200
E=125
F=60
in mm measured from a Trueno wing, but its the same has a Levin, cause I had Levin wings before and they bolt in the same holes.
Same on both sides
12-23-2010, 10:21 PM
aussiefan Wrote:i'm going to take those meassurements you need after x-mas
hehe ok aussiefan
would be awesome if youcan help with your measures,to compare
cheers
Smile
12-23-2010, 10:26 PM
JonnyAE86 Wrote:in mm measured from a Trueno wing, but its the same has a Levin, cause I had Levin wings before and they bolt in the same holes.
Same on both sides
Hurray! Hurray! Hurray! Hurray! Hurray!
thnks jonnyAE86 thnks im having lunch right now then ill come down to chek your measures.
but just 1 doubt
what s a trueno wing?
and levin wings?
are we talking about the same subject? Smile i mean fenders hehe Smile Smile
cheers ill chek these measures
thks Thumbs up!
12-23-2010, 10:41 PM
yeah its the same wing trueno = pop up lights , Levin = fixed headlight version of the ae86
12-23-2010, 11:51 PM
alex-evo Wrote:yeah its the same wing trueno = pop up lights , Levin = fixed headlight version of the ae86
i think no one knows that here... Tongue
12-24-2010, 03:20 AM
yup Smile
p.s
i know trueno = pop up lights and levin fixed ones
but wing?
hehe
i cheked the measures some mm out of distance but...its good i can find a nominal value between the fender and the base
thnk you
12-24-2010, 03:32 AM
JonnyAE86 Wrote:A= 60
B=115
C=175
D=200
E=125
F=60
Same on both sides
btw jonny i sent you a pm
i was cheking your webpage pretty cool
chek your inbox
  brake master cylinder ( 4 holes ) NBU 7 8,426 12-27-2012 04:12 PM
  Question: Where I can find this fender flare? winchi.c 3 6,337 05-01-2011 09:58 AM
Last Post: Bentley
  I need some info about the plastic under the 2 front fender Mattolo 4 6,983 02-22-2010 01:28 PM
Last Post: Mattolo
  Golf Fender Flares for the AE86 (rabbit ??) gon 6 9,395 05-13-2009 08:53 AM
Last Post: robokill
  Fender & Rims Combination Serencebey 11 21,131 03-04-2009 11:04 PM
Last Post: Serencebey
