electric water pump??
04-07-2012, 04:36 AM
Had anyone considered going electric ?
Do some modification on water pump housing and instead of thermostat put electric water pump ?
It consumes less HP and cools more efficiently since flow/rpm is constant.
Any thoughts ?
04-07-2012, 10:05 AM
"It consumes less HP" being electric it puts more load on the alternator which puts more load on the engine. so still consumes HP
04-07-2012, 05:45 PM
The main advantage of an electric water pump is the constant flow.
For me the original pump is good enough to don't require this.
04-07-2012, 08:00 PM
JGeorge, it would be great if you could get basic info before arguing Tongue.
Electric water does cost less energy and offers constant flow.
Stock pumps are designed to offer best flow and efficency at everyday use, thats 2000-4000 rpm.
at high rpm flow is too big, water runs too fast for radiator to cool it down, and on top of it costs 5-10% of power.
Last advantage is that you can run water too cool engine even when engine is off.
electric is definetly way to go for 4age that spend most of it life at high rpm and wot.
04-07-2012, 08:56 PM
I'm not saying not to use them or that they are bad just that they still put a decent load on the engine by increasing the load on the alternater.
I agree with the having better control over flow which is very important.
I have worked on a race car which was running two electric water pumps the alt had to be upgraded to handle the extra load.
04-08-2012, 12:26 PM
I have though about electric waterpump, but I think this will be too unreliable. If it leak just a little bit, the electric motor will stop and the engine will overheat. But, if you manage to find a really quality product, not a cheap china made one found on Ebay, this might be a worth of try.
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
04-08-2012, 01:06 PM
How different is leak on mechanical pump ? Smile
04-08-2012, 04:02 PM
If you want something reliable:
http://www.daviescraig.com.au/Electric_W...-list.aspx
Hurray!
04-09-2012, 05:20 PM
Uzelac Wrote:How different is leak on mechanical pump ? Smile
If a mechanic waterpump leak, it just dripping on the tarmac. A electric motor will short and blow the fuse :wink:
Cars I have owned:
  Electric windows totta Crolla 0 1,975 03-18-2025 11:00 PM
Last Post: totta Crolla
  20v BT - which oil pump? Mylesmck 4 6,033 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 11,730 04-29-2022 05:45 AM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 11,915 12-06-2017 06:48 PM
  fuel line hose from the pump Wikizz 4 8,623 10-16-2017 07:11 PM
Last Post: jdm86gtz
