custom boss kit
08-16-2010, 04:34 PM
custom boss kit
Hi
Have anyone considered or done custom boss/adapter kit for steering wheel ?
Maximum lenght of single adapter is 100mm, i would like more.
I think i will need wheel some 15cm or more closer, which could cost me like 100+ € to buy some boss kit and spacer.
Have anyone considered machining custom sized adapter for AE86 ?
08-17-2010, 02:59 PM
custom boss kit
Something like this:
[Image: AEU86 AE86 - custom boss kit]
08-17-2010, 10:16 PM
custom boss kit
I know what youre getting at about the hub needing to be longer for some steering wheels.. but a long machined hub just sounds dangerous and heavy.
Cant you just combine a hub with a snap-off system to get some extra length? I also know they sell longer hubs for ae86's on ebay sometimes.
08-17-2010, 10:37 PM
custom boss kit
Ivan141 Wrote:Cant you just combine a hub with a snap-off system to get some extra length?
That is exactly what i'm running atm.. It's not an AE86, but i gained a good 10cm with my setup (needed, because i didn't fit under the steering wheel! Big Grin)
6 - 7 cm hub, 4-5 cm snap-off and a 6cm dish on the steering wheel.
seating position for me is perfect now:
08-17-2010, 11:12 PM
custom boss kit
Ivan141 Wrote:I know what youre getting at about the hub needing to be longer for some steering wheels.. but a long machined hub just sounds dangerous and heavy.
I can, and it will cost 100-150$ easily, look ugly and probably more heavy than machined boss kit :/
Steel can be heavy, but i'm sure it can't be dangerous if good made.
08-19-2010, 05:33 PM
custom boss kit
A lump of steel/alu big enough for a hub does also not come very cheap... The danger I see is more in impaling yourself on your hub in an accident than in the material failing (unlikely).
Most aftermarket hubs use a folded metal approach that has lots more 'give' should you get in an accident.
08-20-2010, 01:02 PM
custom boss kit
140mm alu spacer, very lightweight.
http://www.isa-racing.com/product_info.p...erung.html
owau no ka "I"
08-20-2010, 01:44 PM
custom boss kit
Mm.. looks great Smile
Thanks
Certainly will do it.
But, more probably steel, i believe it won't pass 1,5kg mark.
Regards
08-24-2010, 01:30 AM
custom boss kit
Beta stage Smile
Around 2kg and 40e of cost.
ATM wall of thinner part is around 5mm. Will cut it down to 2-2,5mm and half the upper part.
Will drive weight to ~1,2kg
Do not comment the steering wheel style, thanks Smile
Btw. i have some quickrelease here, it weighs more than 400grams. Dont know about standard boss kit but they must be 200+ so it looks 600-700 looks like minimum. Plus you get like 12 more screws.
Dont know why this is more dangerous, but it is more heavy...
08-24-2010, 09:34 PM
custom boss kit
Because the thing is pretty resistant in lengthwise direction. Steering bosses are usualy made in a way that they give in a bit at impact. A rigid aluminum tube will probably not.
  Custom Dash Cluster kazi 14 29,384 10-24-2017 09:05 PM
Last Post: kazi
  Long boss kit FanIsHere 9 14,742 11-14-2016 01:22 AM
Last Post: FanIsHere
  Does anyone know where to buy a short steering hub/boss? krullibull 6 9,511 10-12-2011 10:26 PM
Last Post: krullibull
  4agZe custom fabrication - need pictures Okami 5 16,228 08-08-2011 03:37 AM
Last Post: Saber
  steering wheel/boss/quick release questions Eric 11 17,183 08-19-2008 09:35 AM
Last Post: cavey
