custom boss kit
08-16-2010, 04:34 PM
custom boss kit
Hi
Have anyone considered or done custom boss/adapter kit for steering wheel ? Maximum lenght of single adapter is 100mm, i would like more. I think i will need wheel some 15cm or more closer, which could cost me like 100+ € to buy some boss kit and spacer. Have anyone considered machining custom sized adapter for AE86 ? |
08-17-2010, 02:59 PM
| custom boss kit | |||
08-17-2010, 10:16 PM
custom boss kit
I know what youre getting at about the hub needing to be longer for some steering wheels.. but a long machined hub just sounds dangerous and heavy.
Cant you just combine a hub with a snap-off system to get some extra length? I also know they sell longer hubs for ae86's on ebay sometimes. FABRICA MI DIEM, PVNC! |
08-17-2010, 10:37 PM
custom boss kit
Ivan141 Wrote:Cant you just combine a hub with a snap-off system to get some extra length? That is exactly what i'm running atm.. It's not an AE86, but i gained a good 10cm with my setup (needed, because i didn't fit under the steering wheel! ![]() 6 - 7 cm hub, 4-5 cm snap-off and a 6cm dish on the steering wheel. seating position for me is perfect now:
08-17-2010, 11:12 PM
custom boss kit
Ivan141 Wrote:I know what youre getting at about the hub needing to be longer for some steering wheels.. but a long machined hub just sounds dangerous and heavy. I can, and it will cost 100-150$ easily, look ugly and probably more heavy than machined boss kit :/ Steel can be heavy, but i'm sure it can't be dangerous if good made. |
08-19-2010, 05:33 PM
custom boss kit
A lump of steel/alu big enough for a hub does also not come very cheap... The danger I see is more in impaling yourself on your hub in an accident than in the material failing (unlikely).
Most aftermarket hubs use a folded metal approach that has lots more 'give' should you get in an accident. FABRICA MI DIEM, PVNC! |
08-20-2010, 01:02 PM
custom boss kit
owau no ka "I" |
08-20-2010, 01:44 PM
custom boss kit
Mm.. looks great
![]() Thanks Certainly will do it. But, more probably steel, i believe it won't pass 1,5kg mark. Regards |
08-24-2010, 01:30 AM
custom boss kit
Beta stage
![]() Around 2kg and 40e of cost. ATM wall of thinner part is around 5mm. Will cut it down to 2-2,5mm and half the upper part. Will drive weight to ~1,2kg Do not comment the steering wheel style, thanks ![]() Ivan141 Wrote:I know what youre getting at about the hub needing to be longer for some steering wheels.. but a long machined hub just sounds dangerous and heavy. Btw. i have some quickrelease here, it weighs more than 400grams. Dont know about standard boss kit but they must be 200+ so it looks 600-700 looks like minimum. Plus you get like 12 more screws. Dont know why this is more dangerous, but it is more heavy... |
08-24-2010, 09:34 PM
custom boss kit
Because the thing is pretty resistant in lengthwise direction. Steering bosses are usualy made in a way that they give in a bit at impact. A rigid aluminum tube will probably not.
| Custom Dash Cluster | kazi | 14 | 26,995 |
10-24-2017 09:05 PM Last Post: kazi |
| Long boss kit | FanIsHere | 9 | 12,802 |
11-14-2016 01:22 AM Last Post: FanIsHere |
| Does anyone know where to buy a short steering hub/boss? | krullibull | 6 | 8,677 |
10-12-2011 10:26 PM Last Post: krullibull |
| 4agZe custom fabrication - need pictures | Okami | 5 | 15,189 |
08-08-2011 03:37 AM Last Post: Saber |
| steering wheel/boss/quick release questions | Eric | 11 | 15,709 |
08-19-2008 09:35 AM Last Post: cavey |
![AEU86 AE86 - custom boss kit [Image: AEU86 AE86 - custom boss kit]](https://lh6.ggpht.com/_APKI3b0oh_A/TGqCRruZqcI/AAAAAAAADTE/FCcrUj_0KZg/s400/izometrijski%20pogled.jpg)
![AEU86 AE86 - custom boss kit [Image: AEU86 AE86 - custom boss kit]](http://hachi.uwhost4.net/restauratie/engine-08.jpg)
![AEU86 AE86 - custom boss kit [Image: AEU86 AE86 - custom boss kit]](http://boo50.users.photofile.ru/photo/boo50/95323226/xlarge/116377174.jpg)
