cracked fuel line
03-21-2005, 07:20 PM
cracked fuel line
Full line crack over the bloody wend,im up at college and 150 miles from,was told just cut out the cracked section and replace wit a rubber tube and put a dewbaly clip on both sides.
Would this be safe enoug and good enough to get me home? |
03-21-2005, 08:22 PM
cracked fuel line
If you get it to stay there without leaking to much and drive carefully it shouldn't be no problem.
03-21-2005, 09:22 PM
cracked fuel line
My fuel line crack too, and I use the sam rubber tube, and use on both sides two clips for safety. No problem.
1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
03-22-2005, 09:28 PM
cracked fuel line
as ong as you get a rubber fuel line and not a vacuum line you should be good, even for long applications
You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
03-23-2005, 02:07 PM
cracked fuel line
We have got smoke again, that god its not from a fire, just from the tyres.
Got it sorted yesterday.bloody hole was rite on top of the tank.had to take it out.such a handelin.Got there in the end.at one stage my neighbour thought i had got my lrgs caught under the car, when iwas tryin to push the tank back up |
| fuel line hose from the pump | Wikizz | 4 | 8,335 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
| brake line leaking - how to fix ? | MC_JP | 2 | 6,291 |
04-28-2014 09:47 PM Last Post: MC_JP |
| brake caliper/line fitting | Eifelaner | 9 | 15,858 |
04-15-2013 11:38 AM Last Post: Eifelaner |
| Vacuum Sensor/line hook up help. | Nanaki | 15 | 33,070 |
04-20-2008 04:21 PM Last Post: parrot |
| 20V Vacuum Line Help Needed | domi | 4 | 8,303 |
06-24-2007 09:23 AM Last Post: evfan42 |
