clutch problem
08-12-2008, 01:15 PM
clutch problem
thank you spinny
I checked cardan, tranny and flywheel. remains to check diff, and clutch pressure plate.
Integra Type R vs AE86 Levin
08-12-2008, 05:18 PM
clutch problem
Thanks guys! I ll inform my new mwchanic maybe he knows.
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - clutch problem]
08-14-2008, 10:21 AM
clutch problem
Interesting thread Smile When I installed TRD hard rubber bushings in
the rear suspension linkages, there was immediately some increase
in noise and vibration inside the car. It seems (as could be expected)
that the harder bushings transmit more noise and vibration from the
rear axle into the steel of the body. The body acts an amplifier for
the noise...
It appeared as so the noise was coming from the area of the gearbox
and clutch, and because of a quite different problem, I did fit a new
clutch, pressure plate and throwout bearing. However, it was not until
I had the rear axle overhauled (new pinion bearings and new wheel
bearings) that the noise disappeared. I believe it was probably the
pinion bearings that caused the noise.
Now there is only a small amount more vibration than I had before with
the OEM rubber bushes. It is an acceptable tradeoff for better handling Smile
Hard urethane bushings and spherical bearings can be expected to
transmit even more noise and vibration than TRD rubber bushings Undecided
Cheers... jondee86
08-14-2008, 04:18 PM
clutch problem
Hello, Jondee86,
your explanation makes sence!!!
I also changed to urethane bushing kit together with clutch and flywheel.
Car susp feels much harder with new bushes.
Thank you for your hint!!!
I will check and change rear axle bearings.
08-14-2008, 05:13 PM
clutch problem
rear axle bearing?
08-14-2008, 05:55 PM
clutch problem
yes, rear wheel bearings
08-14-2008, 10:14 PM
clutch problem
Pinion bearings = differential input bearings.
Cheers... jondee86
09-28-2008, 10:10 PM
clutch problem
was this problem ever resolved? The reason I ask is because I am about to change my pilot bearing tomorrow and it occured to me this could be the cause that you're speaking about, but then I get the vibration at clutch biting point from stand still.
  Clutch pedal problem andee17 3 6,389 07-25-2013 11:57 AM
Last Post: jondee86
  Clutch problem Rascal21 4 7,374 05-31-2013 06:00 PM
Last Post: Alex170984
  4agZe problem solved - 99% IC problem Okami 41 48,107 07-12-2012 04:49 PM
Last Post: Okami
  AC problem? Idle problem? KD2229 3 6,409 08-19-2009 02:08 AM
Last Post: KD2229
  Clutch Master Cylinder and Clutch Slave Cylinder fitment? christsang7 2 6,581 07-01-2009 07:48 AM
Last Post: jondee86
