cannabolics hachi...
07-03-2009, 11:27 AM
Post: #51
i tak patrze ze wszyscy co maja ae sa z wroclawia
07-03-2009, 01:06 PM
Post: #52
doggy Wrote:Just one question - why spot weld like you do, and not 2cm weld - 2cm gap? Its more efficient this way? There are some factors saying it would be better if I spot weld this. Firstly, it's a very thin plate and I tend to make holes. Like I've mentioned, I dunno if the reason is my welding equipment, which is rather an unsophisticated or the more realistic reason, my skills I could go on saying that beams tend to crack along the whole length and spot welding makes it "safer", but like you said, I think it's more efficient with 2 cm beams... lochun Wrote:i tak patrze ze wszyscy co maja ae sa z wroclawia Puh Yeah, I think most Polish AE86 are in Wroclaw/Breslau. Let's keep this topic in English ----> rules Philip |
07-03-2009, 03:56 PM
Post: #53
not in all case
sometimes is beter to weld like you |
08-08-2009, 07:43 PM
Post: #54
Mini update
Philip |
08-08-2009, 10:05 PM
Post: #55
now i see that your car have a lot of rust. it is like cheese heh.
08-09-2009, 01:07 AM
Post: #56
The funny about this is, that I've seen a lot of other hachi-rokus and I consider mine to not be a very rusty one
Philip |
08-10-2009, 11:52 AM
Post: #57
you havent luck can, what are you going to do with engine when you done the body? oh, in what colour you want to paint your hachi??
08-10-2009, 12:03 PM
Post: #58
respect for this project!!
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
08-10-2009, 05:39 PM
Post: #59
lochun Wrote:you havent luck can, what are you going to do with engine when you done the body? oh, in what colour you want to paint your hachi?? A have a small port which I'm going to mod. It's going to be a AE92, AE101 and AE111 combo But that's way in the future einneb Wrote:respect for this project!! Thanks man Philip |
08-10-2009, 08:25 PM
Post: #60
time for another mini update
Had a lot of troubles with the right spring nest. It didn't come of as easy as on the other side, so it got a little bit dent. luckily with a lot of small welds, banging, grips and pins I manage to get it right in place again.Of course primed and cleaned before welding it in place I spot welded some the nest I also cut the pocket out finished spot welding inside jeyoo Philip |
