cannabolics hachi...
07-03-2009, 11:27 AM
Post: #51
i tak patrze ze wszyscy co maja ae sa z wroclawia
07-03-2009, 01:06 PM
Post: #52
doggy Wrote:Just one question - why spot weld like you do, and not 2cm weld - 2cm gap? Its more efficient this way? There are some factors saying it would be better if I spot weld this. Firstly, it's a very thin plate and I tend to make holes. Like I've mentioned, I dunno if the reason is my welding equipment, which is rather an unsophisticated or the more realistic reason, my skills I could go on saying that beams tend to crack along the whole length and spot welding makes it "safer", but like you said, I think it's more efficient with 2 cm beams... lochun Wrote:i tak patrze ze wszyscy co maja ae sa z wroclawia Puh Yeah, I think most Polish AE86 are in Wroclaw/Breslau. Let's keep this topic in English ----> rules
Philip |
07-03-2009, 03:56 PM
Post: #53
not in all case
sometimes is beter to weld like you |
08-08-2009, 07:43 PM
Post: #54
Mini update
Philip |
08-08-2009, 10:05 PM
Post: #55
now i see that your car have a lot of rust. it is like cheese
heh.
08-09-2009, 01:07 AM
Post: #56
The funny about this is, that I've seen a lot of other hachi-rokus and I consider mine to not
Philip |
08-10-2009, 11:52 AM
Post: #57
you havent luck
can, what are you going to do with engine when you done the body? oh, in what colour you want to paint your hachi??
08-10-2009, 12:03 PM
Post: #58
respect for this project!!
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
08-10-2009, 05:39 PM
Post: #59
lochun Wrote:you havent luck A have a small port which I'm going to mod. It's going to be a AE92, AE101 and AE111 combo But that's way in the future einneb Wrote:respect for this project!! Thanks man
Philip |
08-10-2009, 08:25 PM
Post: #60
time for another mini update
Had a lot of troubles with the right spring nest. It didn't come of as easy as on the other side, so it got a little bit dent. luckily with a lot of small welds, banging, grips and pins I manage to get it right in place again.Of course primed and cleaned before welding it in place I spot welded some ![]() the nest ![]() ![]() ![]() ![]() I also cut the pocket out ![]() finished spot welding inside ![]() ![]() jeyoo Philip |
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh3.ggpht.com/_Iol8wKsFX58/SnGK0m0XAJI/AAAAAAAABgU/5GQZIagWAek/s640/Foto001.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh5.ggpht.com/_Iol8wKsFX58/SnGK9NHLstI/AAAAAAAABgY/4myivA8jFVE/s640/Foto002.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh5.ggpht.com/_Iol8wKsFX58/SnGLDDSP7LI/AAAAAAAABgc/EMDB0MaLP5Y/s640/Foto003.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh3.ggpht.com/_Iol8wKsFX58/SnGLOSIAvKI/AAAAAAAABgg/7hOwBc34WcQ/s640/Foto006.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh3.ggpht.com/_Iol8wKsFX58/SnGLV4LSiXI/AAAAAAAABgk/MRvEj9vezNg/s640/Foto009.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh6.ggpht.com/_Iol8wKsFX58/SnGNY1Bl18I/AAAAAAAABhA/VYm_CodIIDk/s640/Foto039.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh4.ggpht.com/_Iol8wKsFX58/SoBhj6iUtsI/AAAAAAAABl4/rm0FcOq1suM/s720/Foto012.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh5.ggpht.com/_Iol8wKsFX58/SoBkcjHGlxI/AAAAAAAABmg/Wdndb-SeAZs/s720/Foto001.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh5.ggpht.com/_Iol8wKsFX58/SoBhnVLrVaI/AAAAAAAABl8/nJEfb6Ky2YY/s720/Foto015.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh3.ggpht.com/_Iol8wKsFX58/SoBhq9ynZhI/AAAAAAAABmA/de_jW9Y50RU/s720/Foto019.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh6.ggpht.com/_Iol8wKsFX58/SoBhuom_ZHI/AAAAAAAABmE/MBOqVonWq1Y/s720/Foto020.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh6.ggpht.com/_Iol8wKsFX58/SoBhH9fWU9I/AAAAAAAABlY/EQpiz_LpDv8/s720/Foto003.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh6.ggpht.com/_Iol8wKsFX58/SoBhMEf1K3I/AAAAAAAABlc/XeZ8fSXlAx0/s720/Foto004.jpg)
![AEU86 AE86 - cannabolics hachi... [Image: AEU86 AE86 - cannabolics hachi...]](https://lh6.ggpht.com/_Iol8wKsFX58/SoBhP29ak6I/AAAAAAAABlg/4gwnst5eM5I/s720/Foto005.jpg)
