air fuel ratio gauge!
03-10-2008, 12:14 AM
does any1 know how 2 wire up/install a afr gauge 2 a 86?!
ive got a gauge with 3 wires, a red, black, and blue!
and need 2 know where they wire up 2!
my 02 sensor on the 86 has 1 wire, black in colour. im guessing 1 of the coloured gauge wires go2 this, not sure which 1 tho?!
And the other 2 wire up2 wot?!
can any1 help me out, or has any1 wired up a afr gauge b4
thanks guys Smile
[Image: AEU86 AE86 - air fuel ratio gauge!]
03-10-2008, 01:28 PM
02 sensor on the 86 has 1 wire, black in colour --> thats your signal
and the other 2 wires on the AFM is (+) and (-)
03-10-2008, 10:05 PM
Gtsi-R Wrote:02 sensor on the 86 has 1 wire, black in colour --> thats your signal
sorry yea my 02 sensor has 1 black wire.
wot do you think the + and - wire in2? do you think there just a feed to make the afm gauge work? Undecided
03-11-2008, 11:04 AM
jup I believe that just is feed.. like all the other gauches it has got 1 signal wire and feed!
it is a small band O2 sensor
reaction that I got for this sensor from a salesguy @ zerospec(specialized in Subaru Impreza Turbo), that it is a smallband sensor and will only work good at full trottle.
for the rest to check your O2 continiously you will need a wide band lambda and gauche
but i do not know annything about that yet..
and they are much more expensive..
cheers roel
03-11-2008, 10:00 PM
Gtsi-R Wrote:jup I believe that just is feed.. like all the other gauches it has got 1 signal wire and feed!
cheers roel
yea ive tryd finding a wide band o2 sensor, and they are expensive!
ok thanks for ye help, are c how i get on wiring the gauge up Smile
03-14-2008, 03:13 PM
Buy Bosch LSU4 sensor from VW shops in USA, relative cheap (<80 USD shipped).
03-17-2008, 11:33 AM
WBO2 sensor needs a controller electronic for heating as well as to generate narrowband (programmed) signal. Without heating, the sensor itself didn't last too long...
Narrowband sensors (and AFR gauges attached to it) is not really a solution to monitor proper ratio, it's not more then a lean/rich light. Check wbo2.com for further info.
http://www.ae86.hu
  Air conditioning R134A swap sheppardpat47 2 657 01-22-2026 11:16 PM
Last Post: sheppardpat47
  Fitting Air Con (No PS) to LHD AE86 pack 7 7,390 01-07-2024 11:36 AM
Last Post: CCB
  EUDM gauge cluster banpei 22 12,053 08-15-2023 10:48 PM
  Air Cleaner Assembly Hama86 7 11,975 10-29-2018 03:28 AM
Last Post: Hama86
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 24,034 08-16-2018 01:36 AM
