aftermarket springs
10-30-2006, 01:36 PM
aftermarket springs
I'm looking for aftermarket springs with springrate 25-40% over standart, but without lowering.
11-01-2006, 06:09 PM
aftermarket springs
maybe talk to eibach
Max [email protected] |
11-01-2006, 09:06 PM
aftermarket springs
gt99 Wrote:I'm looking for aftermarket springs with springrate 25-40% over standart, but without lowering. This is a good choice. I'm interested in such springs too! "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
11-09-2006, 11:53 PM
aftermarket springs
And second thing, that I can't find: exhaust manifold for AE86 with blacktop
Is such thing available? |
11-10-2006, 12:50 AM
aftermarket springs
16v versions fit with a few minor modifications. 20v manifolds do exist, but not from any big manufacturer AFAIK, so just modify what you can find.
11-10-2006, 06:08 PM
aftermarket springs
I've just ordered set of front springs (custom made). The guy told me that he can make max 3,4kg/mm with out any lowering. It's approx. 60% more then stock. Price per pair is around 80€. I'll write my impressions in 1 or 2 weeks.
Fun is not the straight line! |
01-02-2007, 02:47 PM
aftermarket springs
Found on Fensport Racing webpage such info
Quote:Custom Spring kit, Handmade to your own specification - Any rate and height - Ideal for Race/Rally applications - A complete set of 4 - Allow 4 weeks for delivery £149.00 I think its interesting offer. Somebody knows AE86 stock spring springrate? |
05-02-2007, 04:28 PM
aftermarket springs
I made a custom springs. In fact, it's a copy of KONI 2220-1056 springs with a little modification of rear springs – they are longer for 15 mm. The wire diameter is 12 mm.
I borrowed original springs from my friend's ae86. Zn - galvanized for rust protection. All included 115€. Car has approximately 2 cm of drop, and it is stiffer then stock. It’s a very good solution for everyday ride and cheap one also. Fun is not the straight line! |
05-02-2007, 05:07 PM
aftermarket springs
Hey max,
Cool! Have some more info about spring rates? Sounds like these are copies from the street springs, not the race springs? So they should fit nicely without doing any modifications other then some nice clean shocks? Sounds like a nice deal! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
05-02-2007, 06:33 PM
aftermarket springs
I've been running custom springs for about 8 years now... stock(USA) AE86 GTS rates are 1.9 front and 2.2 rear. My custom springs are wound to 4.5kg/mm front with a 3.0 rear rate. It also rides at stock height - you can see that very evidently at my fiberglass front bumper as it is above a curb stone
![]() I had the springs made at Turkon Tonk(now bankrupt subsidiary of Suplex) There is still a problem running a linear stiffer spring even at stock ride height... the strut case can still unload more then the preload on such a spring... To remedy that I used 50 year old technology.... strap and clamps! ![]() if you look closely you will see a nylon limiting strap! Instead of "this device" and then "that device"... I just used Illuminas... my custom springs... and 2 - 5' sections of 2" nylon tiedown strap and 4 SS hose clamps! It has worked PERFECTLY for 8 years now... even with the car once sitting on a lift for 17 days!!! Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| HKS valve springs | totta Crolla | 3 | 4,114 |
| Aftermarket / Additional Foglights | decryphe | 6 | 12,793 |
07-08-2017 08:45 AM Last Post: banpei |
| Springs from other vehicles?? | FanIsHere | 16 | 19,189 |
05-17-2016 09:12 AM Last Post: FanIsHere |
| wiring aftermarket tachomete | izanagi | 7 | 11,915 |
05-21-2014 08:15 PM Last Post: banpei |
| 3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 7,873 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
![AEU86 AE86 - aftermarket springs [Image: AEU86 AE86 - aftermarket springs]](http://i79.photobucket.com/albums/j143/oldeskewltoy/oldeskewltoymeet.jpg)
![AEU86 AE86 - aftermarket springs [Image: AEU86 AE86 - aftermarket springs]](http://i79.photobucket.com/albums/j143/oldeskewltoy/PICT0003a.jpg)
