ae86 13B-REW Odessa
12-18-2010, 06:37 PM
ae86 13B-REW Odessa
No that is not a bad thing
![]() I think it is great they invented software wich is able to translate something from russia to english i can understand! You have pictures of your mx41 too? |
12-18-2010, 06:46 PM
ae86 13B-REW Odessa
I am glad that transfer can be understood)))))
12-18-2010, 06:51 PM
ae86 13B-REW Odessa
Eric Wrote:You have pictures of your mx41 too? ![]() Yes, certainly) I since January, 2010 have begun the project with mx41) I Do for the son on its majority) http://www.tourerv.ru/forum/viewtopic.php?f=22&t=58016 |
12-18-2010, 06:55 PM
ae86 13B-REW Odessa
doggy Wrote:[Walaki]D`Lair Wrote:In soviet russa...PROJECT LEADS YOU!!!! No shit man! ![]() ![]() AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-18-2010, 07:20 PM
ae86 13B-REW Odessa
worm72 Wrote:http://www.tourerv.ru/forum/viewtopic.php?f=22&t=58016 Just had a look at the thread, didnt even try to translate all of it but it looks like a lot of work ![]() Love the cars, good luck with that ![]() |
12-18-2010, 10:49 PM
ae86 13B-REW Odessa
Crazy guys, amazing what u build!
![]() would like to drive with this car to our TÜV, they would get parkinson and and tourette syndrom at the same time... ![]() greets from vienna |
12-19-2010, 12:32 PM
ae86 13B-REW Odessa
doggy Wrote:[Walaki]D`Lair Wrote:In soviet russa...PROJECT LEADS YOU!!!! "in soviet russia" is an internet meme A place where the opposite of the norm happens. As shown in the example, instead you driving the car... In Soviet Russia, car drives you! by the way the project is juts mind blowing, keep it up bro! ![]() ![]() ![]() ![]() |
12-20-2010, 01:03 AM
ae86 13B-REW Odessa
Thats what I'm talkin' about
12-20-2010, 03:34 PM
ae86 13B-REW Odessa
Lajoosh Wrote:doggy Wrote:[Walaki]D`Lair Wrote:In soviet russa...PROJECT LEADS YOU!!!! ![]() ONLY "in soviet russia" we use heaviest rail with 5-6mm wall instead of 1mm sheet steel, just correctly folded. And then trying to solve the problem of overweight with expensive fiberglass parts. ![]() ![]() ![]() ![]() http://ae70.blogspot.com/ & http://drft.io.ua/ |
12-20-2010, 11:25 PM
ae86 13B-REW Odessa
In this case gravity threw for manufacturing crossmember has no value. A thickness 2мм... And the weight not on differs from стандартоной crossmember many. Crossmember it is executed in the form of a box - has appreciable improvements before a stamped product..... Rigidity in tens times above.... Moreover. At the equipment wankel the drive I have already won in weight several times... Even without plastic products)))) and rigidity of a design at высокооборотистом and the powerful drive for me is much more important)))) especially if turbine Garret GT42)))) is established) all is counted also all considered at configuration of the given product.....
