Wrong Ignition Timing consequences !?
01-04-2008, 11:34 PM
Car choked and didn't go so well and I changed ignition timing without knowing how much. Now the car goes like crazy, engine never felt so "powerfull".
I can't tell what is my ignition timing because crank pulley is all warn and cracked (I know, I will change it eventualy).
So are they some bad consequences of advance ignition timing ... or any wrong ignition timing from stock (10 BTDC).
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
01-04-2008, 11:57 PM
too much advance could possibly kill your engine, but I think you'd have noticed the noise and starting problems that would cause. Some time ago, I remember robokill was driving around with his timing inadvertently set to about 5 degrees ATDC. Which wont harm anything other than performance.
01-05-2008, 12:31 AM
Ivan141 Wrote:I remember robokill was driving around with his timing inadvertently set to about 5 degrees ATDC. Which wont harm anything other than performance.
AFAIK and some overheating probems... if you push it hard.
01-05-2008, 08:20 PM
yea if the timings out - or + it could corse pinking or a lack in performance!
you just lucky i guess 2 get it spot on by the sounds of it Big Grin
the rite timing for yr engine is -10btdc
  Ignition switch plug and wires Blaze0010 3 4,464 11-25-2024 12:29 PM
Last Post: Blaze0010
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 19,020 07-18-2019 03:52 PM
  4agze timing leon205gti 11 19,622 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 7,500 11-05-2016 01:34 AM
  extracted freedom ecu 16v ignition map ditn 7 13,286 08-22-2016 10:01 AM
Last Post: ditn
