Whining noise HELP PLEASE
03-24-2015, 05:06 PM
Hi all,
I really need help to find this f*%king noise.
I can ONLY hear this whining noise between a range of speed (70 km/h -100 km/h).
I don't know if it comes from the gear box or the rear axle.
For information: I've a new kit of bearing and Crownwheel and Pinion 4.7 .
All is really nice setted up.
Please help me to find this noise. Maybe from the gearbox ?
Thanks in advance.
03-24-2015, 06:09 PM (This post was last modified: 03-24-2015 06:14 PM by Uzelac.)
If you are sure rear axle is setted up good, than it is gearbox.
But surely sounds more like an rear axle.
03-24-2015, 06:37 PM
(03-24-2015 06:09 PM)Uzelac Wrote: [ -> ]If you are sure rear axle is setted up good, than it is gearbox.
I'm pretty sure also but what is the problem ?
New bearings, new C&P.....where is the problem ?
03-24-2015, 09:41 PM
some c&p make noise even they new, or mayby the teeth contack is not that good.. REAR end adjust is not the first DIY you make on car.
03-24-2015, 11:56 PM
which r&p did you buy?
do you use a solid spacer? they need more shims
03-25-2015, 12:35 AM
i have a 4.3 final gear and pinion if you need one
03-25-2015, 08:01 PM
(03-24-2015 11:56 PM)ditn Wrote: [ -> ]which r&p did you buy?
I bought weir performance r&p.
Yes I use solid spacer.
What I don't understand is that the noise is only a a small range of speed.
03-26-2015, 07:21 AM
4TH gear only?
Absent except when between cruising & light acceleration, with a little higher whine accelerating?
4th is direct drive, so less competing gearbox sound lets you hear the rearend more.
R&P will be whiny when not setup right & depending on which way it's out, can make more or less sound the heavier they are loaded.
So what!
03-26-2015, 07:42 AM
My R&P bearing busted once, messed up the R&P clearence (or backlash or whatever you call it in English) and the noise it started to make was gradually increasing from about 30kph. The car was undrivable above 80. Id say your problem comes from the gearbox rather then the rear axle...
86ers.org
AE86 x GXE10
03-26-2015, 07:59 AM (This post was last modified: 03-26-2015 08:01 AM by izanagi.)
(03-26-2015 07:21 AM)allencr Wrote: [ -> ]4TH gear only?
Yes that's exactly that.
(03-26-2015 07:42 AM)Spitfire Wrote: [ -> ]My R&P bearing busted once, messed up the R&P clearence (or backlash or whatever you call it in English) and the noise it started to make was gradually increasing from about 30kph. The car was undrivable above 80. Id say your problem comes from the gearbox rather then the rear axle...
I will try to find a gearbox of my friend and change it to check if the noise is still there.
  Clutch rattling noise on deceleration pack 7 3,456 11-06-2025 12:43 PM
Last Post: pack
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 28,594 04-27-2024 10:04 PM
  Clicking noise from glove box chrisae86 4 5,398 09-08-2022 11:36 PM
Last Post: chrisae86
  TUV RHD AE86 Germany (help please) 4dori 9 11,902 07-17-2019 07:42 PM
Last Post: Hachigo83
  Carb question please help MIGGZFSU 3 7,280 03-29-2017 03:06 PM
Last Post: MIGGZFSU
