Whining noise HELP PLEASE
03-24-2015, 05:06 PM
Hi all,
I really need help to find this f*%king noise. I can ONLY hear this whining noise between a range of speed (70 km/h -100 km/h). I don't know if it comes from the gear box or the rear axle. For information: I've a new kit of bearing and Crownwheel and Pinion 4.7 . All is really nice setted up. Please help me to find this noise. Maybe from the gearbox ? Thanks in advance. |
03-24-2015, 06:09 PM
(This post was last modified: 03-24-2015 06:14 PM by Uzelac.)
If you are sure rear axle is setted up good, than it is gearbox.
But surely sounds more like an rear axle. |
03-24-2015, 06:37 PM
(03-24-2015 06:09 PM)Uzelac Wrote: [ -> ]If you are sure rear axle is setted up good, than it is gearbox.I'm pretty sure also but what is the problem ? New bearings, new C&P.....where is the problem ? |
03-24-2015, 09:41 PM
some c&p make noise even they new, or mayby the teeth contack is not that good.. REAR end adjust is not the first DIY you make on car.
03-24-2015, 11:56 PM
which r&p did you buy?
do you use a solid spacer? they need more shims |
03-25-2015, 12:35 AM
i have a 4.3 final gear and pinion if you need one
03-25-2015, 08:01 PM
(03-24-2015 11:56 PM)ditn Wrote: [ -> ]which r&p did you buy?I bought weir performance r&p. Yes I use solid spacer. What I don't understand is that the noise is only a a small range of speed. |
03-26-2015, 07:21 AM
4TH gear only?
Absent except when between cruising & light acceleration, with a little higher whine accelerating? 4th is direct drive, so less competing gearbox sound lets you hear the rearend more. R&P will be whiny when not setup right & depending on which way it's out, can make more or less sound the heavier they are loaded. So what! |
03-26-2015, 07:42 AM
My R&P bearing busted once, messed up the R&P clearence (or backlash or whatever you call it in English) and the noise it started to make was gradually increasing from about 30kph. The car was undrivable above 80. Id say your problem comes from the gearbox rather then the rear axle...
86ers.org AE86 x GXE10 |
03-26-2015, 07:59 AM
(This post was last modified: 03-26-2015 08:01 AM by izanagi.)
(03-26-2015 07:21 AM)allencr Wrote: [ -> ]4TH gear only?Yes that's exactly that. (03-26-2015 07:42 AM)Spitfire Wrote: [ -> ]My R&P bearing busted once, messed up the R&P clearence (or backlash or whatever you call it in English) and the noise it started to make was gradually increasing from about 30kph. The car was undrivable above 80. Id say your problem comes from the gearbox rather then the rear axle...I will try to find a gearbox of my friend and change it to check if the noise is still there. |
| Clutch rattling noise on deceleration | pack | 7 | 3,456 |
11-06-2025 12:43 PM Last Post: pack |
| TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 28,594 |
04-27-2024 10:04 PM Last Post: banpei |
| Clicking noise from glove box | chrisae86 | 4 | 5,398 |
09-08-2022 11:36 PM Last Post: chrisae86 |
| TUV RHD AE86 Germany (help please) | 4dori | 9 | 11,902 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
| Carb question please help | MIGGZFSU | 3 | 7,279 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
