What light flywheel?
11-28-2010, 09:33 PM
Hi, i looked for the forum, but i haven't any conclusion.
In a few weeks i'm gonna change the clutch, and i was thinking to instal a light flywheel, some questions:
* Will feel the difference in a OEM engine (only will have a new cams)??
* What flywheel (no too much expensive like a beautiful TodaRacing)? and compatible with the OEM clutch
* Another option is to make a OEM flywheel to light flywheel (eating the "fat"), Anybody knows where would i remove the weight? (a turner work)
Thanks
[Image: AEU86 AE86 - What light flywheel?]
12-03-2010, 09:54 PM
1. If you go to an aftermarket flywheel you will notice a LOT of difference. Some difference with a blacktop flywheel, but not nearly as much. Because it isn't as light as the aftermarkets, but it is lighter than the stock.
2. I'd recommend a chromoly/steel type flywheel like the toda/jun/etc.
3. NO. Do not do this if you like your feet.
Andrew
12-03-2010, 10:13 PM
T_AE86 Wrote:* Another option is to make a OEM flywheel to light flywheel (eating the "fat"), Anybody knows where would i remove the weight? (a turner work)
Thanks
assassin10000 Wrote:3. NO. Do not do this if you like your feet.
Andrew
Its one thing with a V8 engine or V6 that only spin to 6000 rpm, but with the potential to spin well over 7000, a reduced "fat" flywheel is not safe. To add to that, an aluminum one is better, but as Andrew points out, try to stick with a steel unit, far safer then lightening an aftermarket flywheel
Dan -
12-03-2010, 10:59 PM
Way too much uninformed comment, speculation and internet myth
about this topic. I suggest you try telling these guys they are doing it
all wrong... http://www.racetep.com/flywheel.html
Cheers... jondee86
12-06-2010, 11:18 AM
+1 with jondee
lots of people in the hillclimbing races drive lightened OEM flywheels above 9000rpm
http://monkeymagic86.wordpress.com
12-06-2010, 11:38 AM
Do you know someone who did it on 4AGE ?
Sounds interesting.
Have local shop which is doing this and similar stuff, but they don't have expirience with 4AGE neither.
  light weight Flywheel filh 9 11,673 02-05-2018 05:20 PM
Last Post: filh
  crank 6 bolt flywheel DJexor 5 11,227 12-05-2016 08:21 AM
Last Post: d3nso
  Flywheel fitting totta Crolla 11 17,388 11-24-2013 05:31 PM
Last Post: Apsogos
  Flywheel and clutch kit 86Pilot 1 4,768 12-01-2011 01:26 PM
Last Post: 86Pilot
  flywheel balance totta Crolla 4 7,118 06-28-2010 11:21 AM
