What is this?
09-19-2011, 02:03 PM
What is this?
[Image: AEU86 AE86 - What is this?]
in the yellow ring on the picture..
two vacum hoses goes inn to it, and it has a adjusting screw on it.
What is that?
Thanks Smile
09-19-2011, 02:07 PM
What is this?
i had a similar unit on my gze, when i remember right it was for idle up on the AC system...
greets
09-19-2011, 02:10 PM
What is this?
the two hoses goes before and after the throttle body.
has no reaction when i adjusting the screw.
The AC is removed
09-19-2011, 05:24 PM
What is this?
Looks more like some kind of emission control device, evap canister maybe?
Never seen one on a MAP sensored car...
09-19-2011, 06:14 PM
What is this?
AC idle up, adjust its large nylon/plastic screw for whatever differential you want/need.
So what!
09-19-2011, 06:48 PM
What is this?
So i can remove that valve when the AC compressor and all that shit is removed?
09-20-2011, 10:40 AM
What is this?
Yes. If you don't have any A/C you don't need an A/C idle-up valve. Just
make sure you block the connections to the intake manifold and air intake
ducting. BTW... nice engine bay Smile
Cheers... jondee86
09-20-2011, 12:00 PM
What is this?
Jepp, thanks guys! Smile
