Velocity stacks lenght question
01-07-2009, 11:44 PM
I want to buy the toda straight trumpets (air horns, velocity stacks or whatever you want to call them) but I don´t really know which length I should get. They have 30 and 55 mm for the silvertop 4ag.
I have standard camshafts, custom 4-2-1 header, 11:1 compression and a port & polish job. Blacktop ECU and MAP. Everything else stock.
When I tried 63mm trumpets I felt more medium range torque but less high end power than with the stock parts so I want to shorter ones but I don´t want to lose to much medium range torque if I go with the 30mm
Do you know if there´s any dyno chart or something I can check out to compare the power/torque curve with different trumpet lengths? what experience do you have with different lengths? Is it best to use the horns with or without the air box?
thanks,
Luis
01-08-2009, 12:48 AM
I doubt you'll find Dyno plots with different length trumpets.
Other parts fitted to the engine will have an effect so every engine with these trumpets fitted will have a different effect.
I don't know how much they are but you could buy a set of each, try them both and sell on the ones you don't want.
The airbox should make a big different to induction noise but litte/no difference to power.
However you might find aftermarket trumpets do not fit in the airbox anyway.
BTW do you know the length of the standard trumpets?
01-08-2009, 01:24 AM
the only way to actually know is to test both with YOUR engine in the dyno.
But from what I have read the 20v likes short trumpets in almost all RPM's .... (due to the fact that the distance from the itb end to the valve is quite long already.)
01-08-2009, 01:26 AM
short trumpet -> power (high rev)
long trompet -> torque (less power)
depend of how you drive Wink
01-08-2009, 01:44 AM
i have a mate who races with me and his ram tubes in his black top 20 v are about 75mm long ,his engine is std and with a ae86 exhaust manifold attached to the engine as well .with his own mandrell secondary header pipes
this motor idles and makes max power at 7800 and rev cut at 8200 rpm
so i would start with a longer 1 and go from there
01-09-2009, 02:09 PM
Where can you buy them from? I run mine with no trumpets and just a pipercross filter fitted, I don't have room for the standard ones.
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
01-09-2009, 02:38 PM
@ last post http://www.technotoytuning.com very good, quick postage to Ireland
01-09-2009, 06:30 PM
those are 75mm long!! toda´s longest trumpets for silver top are 55mm. I think I´ll stay with the TODA lengths.
I´ve found a guy here that makes trumpets for a much lower price though so i´m getting the 30mm and 55mm and then straight to the dyno to end this discussion.
this is the page with all the TODA trumpets specs
http://www.toda-racing.co.jp/en/product/...4ag-3.html
01-09-2009, 06:37 PM
byd1380 Wrote:Where can you buy them from? I run mine with no trumpets and just a pipercross filter fitted, I don't have room for the standard ones.
take a look at this link, they have distributors in england
http://www.toda-racing.co.jp/en/link/link.html
01-09-2009, 11:25 PM
Quote:I´ve found a guy here that makes trumpets for a much lower price
Ha !!! The best length for trumpets is a never ending discussion Smile As
soon as you fix the length, it means that the effect will be most felt at
a certain rpm due to the tuned effect of the inlet tract. A different length
will be more effective at some other rpm range. And each person has
a different goal for their engine.
For this reason there is a lot of development on variable length trumpets
that change length while driving, according to the rpm and load on the
engine (like VVTi). Also, there are some people who say that the BT and
even the ST throttles are too big for a 1600cc engine. This results in an
engine that is biased towards high rpm, and does not produce much
power down low.
I will be interested to see the curves you get on the dyno... good luck Smile
Cheers... jondee86
  Velocity stacks = more power, now which to get? 4000GT 38 65,822 02-22-2012 01:19 AM
Last Post: jondee86
  front strut lenght comparison problems fax0815 6 10,702 01-25-2011 04:12 PM
Last Post: fax0815
  intake runner lenght with ITBs discussion Bean 30 55,949 03-27-2010 07:45 AM
Last Post: 4000GT
  Silvertop velocity stacks - trumpets? byd1380 17 23,119 09-16-2009 12:35 PM
Last Post: byd1380
  another velocity stack question. AEeighty-six 12 23,444 06-22-2009 04:03 PM
Last Post: isac
