Tutorial : Megasquirting an European (MAP) AE86 (4age)
03-30-2009, 05:07 PM
Post: #41
fuel + spark maps with 288/272 please.
What cam timing for 288/272?
Also can you psotdyno curve with AFR when finished?
03-30-2009, 07:30 PM
Post: #42
irishtwincam Wrote:24+4 should cause problems?
The 4 tooth are too close to 24 tooth.
There is not enough lead time to allow triggering without reseting
"degree counter" in the ecu software?
Events are too close together and too close to TDC.
Also Im suprised you ahve success witht he stock loom too.
EURO AE86 has NE, G and G- wires that are not shielded.
Last time we tried this we had LOTS of noise on the wires.
On this setup megasquirt is used in MSnS mode .
Only the 4 tooth wheel is used.
The shield of the wire is not very important since the VR sensor wire is about 25cm long only.
After that it arrives to the MAF ignitor where it is converted to digital. After it is in digital mode the shield is not very important.
03-31-2009, 10:13 AM
Post: #43
Your using the stock igniter to convert the Sin wave into a digital signal Big Grin
Interesting!
03-31-2009, 03:23 PM
Post: #44
yes ..... the MAF one ....
it says on the Tutorial ....
stock stuff works best .......
04-01-2009, 11:59 PM
Post: #45
Er, spark timing please Big Grin pretty pleae Big Grin
04-23-2009, 09:06 AM
Post: #46
Hi Guys!
Finally my 4A-GE is working very nice with the MegaSquirt V2.2.
Last weekend I passed the Hungarian Drift Association PRO class license with my AE86.
Smtg like this : Wave
Regards,
Z
http://ae86.blog.hu - closed
2006 Toyota Corolla Verso 2.2 D4-D
1992 JDM Nissan Silvia PS13 RB26DETT powered
04-27-2009, 04:02 PM
Post: #47
Gon, AE86_z,
Did you use 20v TPS? How do you wired it to the harness?
I have mine this ways, but don't work
[code:1:0523451c01]tps side > loom side
brown > yellow
Blue > red
Red > Blue
Yellow > brown[/code:1:0523451c01]
I get FLOOD CLEAR in megatune and calibration process give same value on min/max fields.
regards
04-27-2009, 07:24 PM
Post: #48
i did use the 20v tps cant remeber how i wired it.
try diferent ways , you wont burn it
04-28-2009, 08:51 AM
Post: #49
isac Wrote:Gon, AE86_z,
[code:1]tps side > loom side
brown > yellow
Blue > red
Red > Blue
Yellow > brown[/code:1]
regards
Hi,
I have the AE101 TPS too.
The wires are here:
AE101
Throttle Position Sensor 1 Y TPS constant voltage supply TPS power supply terminal
Throttle Position Sensor 2 R TPS wiper track signal ECU terminal ‘VTA’
Throttle Position Sensor 3 B TPS idle position microswitch ECU terminal ‘IDL’
Throttle Position Sensor 4 BR TPS sensor earth ECU ‘E2’ sensor ground terminal.
AE86
Throttle Position Sensor 1 B VCc TPS power supply terminal
Throttle Position Sensor 2 R VTA ECU terminal ‘VTA’
Throttle Position Sensor 3 B IDL ECU terminal ‘IDL’
Throttle Position Sensor 4 BR E2 ECU ‘E2’ sensor ground terminal.
Y=Yellow
B=Blue
R=Red
BR=Brown
Regards,
Z
04-28-2009, 08:28 PM
Post: #50
Thanks! Everything works!
Big Grin map sensor cheating? fdsjakl890 7 270 Yesterday 05:13 PM
Last Post: decryphe
  AFM to Map Conversion ps13michi 3 4,439 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 13,819 02-10-2020 06:39 PM
Last Post: Power_uP
  European/UK vs Japanese Levin "Glass Grill" mad.matt 3 6,880 10-20-2017 02:47 PM
  extracted freedom ecu 16v ignition map ditn 7 10,304 08-22-2016 10:01 AM
Last Post: ditn
