Tutorial : Megasquirting an European (MAP) AE86 (4age)
03-23-2009, 12:52 PM
will_drift_4_food Wrote:Awesome info. Thumbs up! Keep it coming. I don't know why I'm having such a hard time with it. Maybe it's because my "swap-in-a-box" was made up of parts from different areas of the world. Who knew there were so many variations? I think I read somewhere that even the dealerships are sometimes uncertain which equipment came on which chassis. I think doing two projects at once is also confusing me. Banging head I'll check my ignitors again tomorrow.
When you hooked up the injectors management, you need to check that all the four injectors got 12V from ECU (ignition switch ON). I made new injector wiring, because my original harness didn't work.
Almost started yesterday Confused
http://ae86.blog.hu - closed
2006 Toyota Corolla Verso 2.2 D4-D
1992 JDM Nissan Silvia PS13 RB26DETT powered
03-23-2009, 01:39 PM
Yeah, They all have +12V when the Key is "ON". I need to make sure that the injectors maintain that during cranking. I got a set of noid lights the other day; I need to make sure that they are firing at all.
I got the engine, harnesses, transmission, etc. as a lot from a guy that was going to use it for a Locost/Seven project. I think the harness is a Euro MAP harness, but I don't know if the ECU is Euro or JDM. The injectors are blue, low impedance injectors. I know that the ignitor I received is an VAST ignitor. But, the dizzy was an ESA dizzy. So, nothing seems to go together.
I have since purchased two ESA ignitors, but aside from the fact that they plug into the harness better, I am still right where I started. I'll keep at it.
Jason Clark
JC
Atlanta, GA
1984 AE86 SR5 Coupe
1987 MA70 (60-1,.70A/R; AEM EMS)
1994 Honda Accord EX
03-23-2009, 03:06 PM
AE86_Z Wrote:When you hooked up the injectors management, you need to check that all the four injectors got 12V from ECU (ignition switch ON). I made new injector wiring, because my original harness didn't work.
the 12v shouldn't come from the ecu , they need to come from your harness.... the only connection between ecu and injectors is the ground wire.
Injectors should always have 12v+ (with key switch ON) and the ECU gives ground to the injectors for them to fire.
good work Smile keep going ...
03-23-2009, 11:38 PM
Sorry.... 12V coming from the harness, from a switched battery source, of course.
Banging head
03-24-2009, 10:18 PM
Hi guys!
We made it: Hurray! Hurray! Hurray! Hurray! Hurray!
http://www.youtube.com/watch?v=1j1hBWq78xo
Thanks for your help guys:Respect! Respect! Respect! Respect! Respect!
Gon
Apardal
ZDoman
That was a real team work Respect!
03-24-2009, 10:31 PM
I'm really happy for you mate Smile
03-29-2009, 09:56 PM
Hi guys!
My engine is ready to tune, today we did the 1st run with MegaSquirt:
03-30-2009, 12:36 AM
Thumbs up!
03-30-2009, 01:01 AM
God damn, great work guys!
"Bad" thing is i allready started to search the net for great MS deals. Got any recommendation ?Smile
03-30-2009, 09:45 AM
Uzelac Wrote:God damn, great work guys!
Thx Smile
You can buy all the things what you need from diyautotune.com. Cheap prices, very fast delivery.
Regards,
Z
Big Grin map sensor cheating? fdsjakl890 8 880 08-26-2025 01:12 PM
  AFM to Map Conversion ps13michi 3 4,515 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 13,948 02-10-2020 06:39 PM
Last Post: Power_uP
  European/UK vs Japanese Levin "Glass Grill" mad.matt 3 6,932 10-20-2017 02:47 PM
  extracted freedom ecu 16v ignition map ditn 7 10,392 08-22-2016 10:01 AM
Last Post: ditn
