Toyota rear caliper
01-25-2014, 11:54 AM
Toyota rear caliper
Does anyone know of a way to identify genuine Toyota rear brake calipers ?
(The hand brake pivot on genuine Toyota calipers runs in a needle roller bearing and this bearing is not fitted to pattern part calipers) Is it as simple as Toyota ones say Toyota on them ? An analogue brain in a digital World |
01-26-2014, 10:13 AM
Toyota rear caliper
Aftermarkets put a bronze bushing in the oem caliper.
Andrew |
01-26-2014, 11:53 AM
Toyota rear caliper
Sorry Andrew I didn't really make the question very clear I should have asked if it is possible to tell the Toyota part from the outside without dismantling it ?
01-27-2014, 08:32 AM
Toyota rear caliper
Nope.
Andrew |
01-27-2014, 12:01 PM
Toyota rear caliper
assassin10000 Wrote:Nope. lol, that's that then
01-27-2014, 02:15 PM
Toyota rear caliper
My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD |
02-02-2014, 10:41 PM
Toyota rear caliper
Post no.13 in this thread:
http://www.ae86irl.com/forum/showthread....er+bearing |
02-02-2014, 11:19 PM
Toyota rear caliper
I wonder if that bearing could be retro fitted to a caliper with the bronze bush ?
The hand brake pivot rubber seal is also different on the repro calipers as it does not locate in the same way as the Toyota seal does and the Toyota seal will not fit into the recess on the repro caliper, not on my one anyway. An analogue brain in a digital World |
| Rear Caliper Rebuild | mad.matt | 16 | 22,845 |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 5,305 |
| brake caliper/line fitting | Eifelaner | 9 | 15,847 |
04-15-2013 11:38 AM Last Post: Eifelaner |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 8,328 |
| max brake disc thickness ae86 caliper+heel and toe question | ditn | 26 | 35,819 |
10-02-2012 05:00 PM Last Post: ditn |
![AEU86 AE86 - Toyota rear caliper [Image: AEU86 AE86 - Toyota rear caliper]](http://www.toyodiy.com/parts/diag_2pTt63.png)
