Tie rods
01-08-2008, 03:03 PM
Tie rods
I always felt that my steering was a bit loose.
Apparently my inner tie rod on the right side is worn out and has a lot of play.
I am going to replace them both and wanted to add a 5mm spacer aswell for more angle.
I have 2 choises:
1: buy nipparts inner tie rods and add some washers to make a 5mm spacer
[img name=]http://www.aeu86.org/files/af/afbeeldingaspx_137.jpg[/img]
2: buy the new megan racing inner tie rods which already have a 5mm spacer on them.
[Image: AEU86 AE86 - Tie rods]
The nipparts cost about 50 euro.
The megan 120$ plus shipping would come to around 120euro.
I am just wondering about the quality of the megans compared to the nipparts...is the 70euro worth it or not?
01-08-2008, 04:09 PM
Tie rods
Have no experience with Megan.
There are also others building those like JIC (265.- Chf), Noby Booth.
JIC will be very good quality. Thumbs up!
Just to give alternatives.
The nipparts with your own spacer could also be a good choice.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
01-09-2008, 12:02 AM
Tie rods
i would just run standard ones just with a spacer... cheaper, quality would be no worse then megans, most likly better...
01-17-2008, 09:06 PM
Tie rods
The tie rods pictured just look like standard ae86 with a section machine down to produce the extra area for the rack to move. Powersteering ae86 tie rods are 5-10mm shorter depending on manufacture than non powersteering ones. 70 series are 15-20mm longer than this again.
heres is a pic but do check with your manufacture or No Hachi if its the case there.
http://img229.imageshack.us/img229/5863/...703vo2.jpg
02-02-2008, 01:44 PM
Tie rods
Just use stock rods, and buy my precision engineered Battleversion 5mm spacers for £20 inc shipping!
Dont use washers, they have slop and can help the tie rod work loose!!!
PM me Smile
02-02-2008, 03:32 PM
Tie rods
Alex pfeifer: "Just get 4 14mm split lock washers. Put 2 on each inner tie rod. Done and done."
:wink:
02-02-2008, 05:52 PM
Tie rods
Bubble_Drift Wrote:Alex pfeifer: "Just get 4 14mm split lock washers. Put 2 on each inner tie rod. Done and done."
:wink:
Haha... not really. They will be a sloppy fit, and you dont want any squirming between a tie-rod and a steering rack Wink
And you forgot the Loctite Wink
Totally your choice. But if you want a proper, riliable, precision fit, buy the Battleversion spacers. I still have 2 sets left Smile
02-03-2008, 12:40 AM
Tie rods
They fitted fine. And I didn't forget the locktite. :wink:
For those wondering: When you use a spacer the locking rings become useless, so you need to use locketite on the thread of the tie rod that goes into the rack.
PS: Alex Pfeifer = Battleversion!
02-03-2008, 01:07 AM
Tie rods
So if i use 70series tie rods which are 20mm longer than OEM do i get extra lock?
Or i got it wrong? Confused
02-03-2008, 11:57 AM
Tie rods
You got it wrong, the extra lock comes from the added lenght of the spacer on the steering rack that can be pulled into the housing.
  Trueno - Headlight Rods pack 16 18,608 04-27-2012 11:23 AM
Last Post: pack
  Forged rods for 4AGE 20v options 4000GT 12 21,975 07-17-2011 08:50 PM
Last Post: Jimmi The Kid
  Longer Tie rod / steering ends meshin 2 7,606 11-10-2010 01:57 PM
Last Post: meshin
  I need rods 40mm crank journal, and 20mm wrist pin!!!! filip.alin 4 10,884 11-04-2010 06:57 AM
Last Post: filip.alin
  Outer TIE RODS - interchangeability? Apolan 8 11,204 08-11-2010 06:36 PM
Last Post: Apolan
