Tie rods
01-08-2008, 03:03 PM
Tie rods
I always felt that my steering was a bit loose.
Apparently my inner tie rod on the right side is worn out and has a lot of play. I am going to replace them both and wanted to add a 5mm spacer aswell for more angle. I have 2 choises: 1: buy nipparts inner tie rods and add some washers to make a 5mm spacer [img name=]http://www.aeu86.org/files/af/afbeeldingaspx_137.jpg[/img] 2: buy the new megan racing inner tie rods which already have a 5mm spacer on them. ![]() The nipparts cost about 50 euro. The megan 120$ plus shipping would come to around 120euro. I am just wondering about the quality of the megans compared to the nipparts...is the 70euro worth it or not? |
01-08-2008, 04:09 PM
Tie rods
Have no experience with Megan.
There are also others building those like JIC (265.- Chf), Noby Booth. JIC will be very good quality. Just to give alternatives. The nipparts with your own spacer could also be a good choice. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
01-09-2008, 12:02 AM
Tie rods
i would just run standard ones just with a spacer... cheaper, quality would be no worse then megans, most likly better...
01-17-2008, 09:06 PM
Tie rods
The tie rods pictured just look like standard ae86 with a section machine down to produce the extra area for the rack to move. Powersteering ae86 tie rods are 5-10mm shorter depending on manufacture than non powersteering ones. 70 series are 15-20mm longer than this again.
heres is a pic but do check with your manufacture or No Hachi if its the case there. http://img229.imageshack.us/img229/5863/...703vo2.jpg |
02-02-2008, 01:44 PM
Tie rods
Just use stock rods, and buy my precision engineered Battleversion 5mm spacers for £20 inc shipping!
Dont use washers, they have slop and can help the tie rod work loose!!! PM me
02-02-2008, 03:32 PM
Tie rods
Alex pfeifer: "Just get 4 14mm split lock washers. Put 2 on each inner tie rod. Done and done."
:wink: |
02-02-2008, 05:52 PM
Tie rods
Bubble_Drift Wrote:Alex pfeifer: "Just get 4 14mm split lock washers. Put 2 on each inner tie rod. Done and done." Haha... not really. They will be a sloppy fit, and you dont want any squirming between a tie-rod and a steering rack ![]() And you forgot the Loctite ![]() Totally your choice. But if you want a proper, riliable, precision fit, buy the Battleversion spacers. I still have 2 sets left
02-03-2008, 12:40 AM
Tie rods
They fitted fine. And I didn't forget the locktite. :wink:
For those wondering: When you use a spacer the locking rings become useless, so you need to use locketite on the thread of the tie rod that goes into the rack. PS: Alex Pfeifer = Battleversion! |
02-03-2008, 01:07 AM
Tie rods
So if i use 70series tie rods which are 20mm longer than OEM do i get extra lock?
Or i got it wrong? |
02-03-2008, 11:57 AM
Tie rods
You got it wrong, the extra lock comes from the added lenght of the spacer on the steering rack that can be pulled into the housing.
| Trueno - Headlight Rods | pack | 16 | 19,182 |
04-27-2012 11:23 AM Last Post: pack |
| Forged rods for 4AGE 20v options | 4000GT | 12 | 22,328 |
07-17-2011 08:50 PM Last Post: Jimmi The Kid |
| Longer Tie rod / steering ends | meshin | 2 | 7,714 |
11-10-2010 01:57 PM Last Post: meshin |
| I need rods 40mm crank journal, and 20mm wrist pin!!!! | filip.alin | 4 | 11,088 |
11-04-2010 06:57 AM Last Post: filip.alin |
| Outer TIE RODS - interchangeability? | Apolan | 8 | 11,551 |
08-11-2010 06:36 PM Last Post: Apolan |
![AEU86 AE86 - Tie rods [Image: AEU86 AE86 - Tie rods]](http://i23.photobucket.com/albums/b393/driftform/Manualinner.jpg)
