Streering problem!
01-14-2008, 05:50 PM
Streering problem!
I am having a little problem with my steering. When i steer to the left or right i can feel that the wheel gets a little hard. Could this be the steering links or barrings?
Anyone that can give me some tips about what i could be? This started after the first snow fall! Thx |
01-14-2008, 08:58 PM
Streering problem!
Have you checked the tyre pressures ?
01-14-2008, 10:01 PM
Streering problem!
Usually it is the universal joint from the rack to the steering column you can can remove it without taking the rack or column off, if you find a tight spot in the joint thats you problem.
01-24-2008, 08:55 PM
Streering problem!
road rally Wrote:Usually it is the universal joint from the rack to the steering column you can can remove it without taking the rack or column off, if you find a tight spot in the joint thats you problem.I have been chasing a steering problem all around my front suspension for ages, after reading the above I checked the joint and found it to be stiff, changed it and now it's totally sorted, mr road rally thanks !! An analogue brain in a digital World |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 51,494 |
07-12-2012 04:49 PM Last Post: Okami |
| AC problem? Idle problem? | KD2229 | 3 | 6,764 |
08-19-2009 02:08 AM Last Post: KD2229 |
