Stock 4A-GE specification
04-17-2013, 02:31 PM
I'd like to determine as most as possible, about this engine.
At the beginning of the question, is this graph looks properly: [img name=]http://www.aeu86.org/files/_4/thumbs/t__4a_ge_dyno_916.jpg[/img] Is there a graph which presents the fuel consumption depending on rpm ? What is the longevity of this unit ? |
04-17-2013, 08:03 PM
neither of those dyno plots is a 4AGE... (they appear to be the same) The torque output exceeds most 4AGE engines capability.
This is what a stock 4AGE plants (@ the flywheel) ![]() Longevity... I know quite a few original 4AGE engines exceeding 200k miles Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-17-2013, 10:10 PM
thanks my Friend.
U are right it's actually a real problem. I have never seen two the same dynos. And how long does this engine lives on average ? I assume that this data concerns road usage ? |
04-17-2013, 10:37 PM
Mine did 270000 km of which at least 10000km on circuit/rallyish events
04-17-2013, 10:43 PM
wow nice result - thanks for info. I read that these engines have a long lifespan. Seems that this is itrue.
I still have in mind when I spoke with Porsche 914 owner once, his engine can withstand only 5000-6000km |
04-22-2013, 07:53 AM
I'm close to 180'000km and no problem regarding the engine yet...
mix between ultra short driving/long distance and track. AE86 ex-daily |
04-22-2013, 09:33 AM
Mine had 400 000 km when I bought it, it ran very good. I guess it haven't lost more than 5-10% of power.
Engine electronics is bigger problem, headn and short block can last, AFM and similar stuff cant. |
04-22-2013, 10:33 AM
Thanks guys, I hope to create statistics which will have average value and something like lifetime random variance. Therefore every information useful. And those relating directly to failure the most. Is there a safe rpm limit beyond which gamble begins ? or cutting off will not allow for that ?
04-22-2013, 05:00 PM
damusto Wrote:Thanks guys, I hope to create statistics which will have average value and something like lifetime random variance. Therefore every information useful. And those relating directly to failure the most. Is there a safe rpm limit beyond which gamble begins ? or cutting off will not allow for that ? MOST of the ECU's cut out @ 7500 rpm. As you can see from the dyno chart the engine makes peak power @ 6600. So... it doesn't ever break out of its safe operating zone since the camshafts limit power production before the ECU limits the rpm range. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-22-2013, 05:50 PM
Hm thats interesting U see...
quoting from autocar road test from 1984: "capability of reving to no less than 7700 rpm" But it might be true, my FSM says the tachometer accuracy is + /-200rpm btw I can also simulate this ... I assume, therefore, that this is rather +200 rpm ? |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 3,509 |
| 82mm Stock compression Pistons | apardal | 4 | 5,679 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 19,054 |
| Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 8,616 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
| stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 8,009 |
02-20-2016 11:48 AM Last Post: Bean |
![AEU86 AE86 - Stock 4A-GE specification [Image: AEU86 AE86 - Stock 4A-GE specification]](http://www.ae92gts.com/images/4age_power.jpg)
