Stock 4A-GE specification
04-17-2013, 02:31 PM
I'd like to determine as most as possible, about this engine.
At the beginning of the question, is this graph looks properly:
[img name=]http://www.aeu86.org/files/_4/thumbs/t__4a_ge_dyno_916.jpg[/img]
Is there a graph which presents the fuel consumption depending on rpm ?
What is the longevity of this unit ?
04-17-2013, 08:03 PM
neither of those dyno plots is a 4AGE... (they appear to be the same) The torque output exceeds most 4AGE engines capability.
This is what a stock 4AGE plants (@ the flywheel)
[Image: AEU86 AE86 - Stock 4A-GE specification]
Longevity... I know quite a few original 4AGE engines exceeding 200k miles
Dan -
04-17-2013, 10:10 PM
thanks my Friend.
U are right it's actually a real problem. I have never seen two the same dynos.
And how long does this engine lives on average ?
I assume that this data concerns road usage ?
04-17-2013, 10:37 PM
Mine did 270000 km of which at least 10000km on circuit/rallyish events Thumbs up!
04-17-2013, 10:43 PM
wow nice result - thanks for info. I read that these engines have a long lifespan. Seems that this is itrue.
I still have in mind when I spoke with Porsche 914 owner once, his engine can withstand only 5000-6000km
04-22-2013, 07:53 AM
I'm close to 180'000km and no problem regarding the engine yet...
mix between ultra short driving/long distance and track.
04-22-2013, 09:33 AM
Mine had 400 000 km when I bought it, it ran very good. I guess it haven't lost more than 5-10% of power.
Engine electronics is bigger problem, headn and short block can last, AFM and similar stuff cant.
04-22-2013, 10:33 AM
Thanks guys, I hope to create statistics which will have average value and something like lifetime random variance. Therefore every information useful. And those relating directly to failure the most. Is there a safe rpm limit beyond which gamble begins ? or cutting off will not allow for that ?
04-22-2013, 05:00 PM
damusto Wrote:Thanks guys, I hope to create statistics which will have average value and something like lifetime random variance. Therefore every information useful. And those relating directly to failure the most. Is there a safe rpm limit beyond which gamble begins ? or cutting off will not allow for that ?
MOST of the ECU's cut out @ 7500 rpm. As you can see from the dyno chart the engine makes peak power @ 6600. So... it doesn't ever break out of its safe operating zone since the camshafts limit power production before the ECU limits the rpm range.
Dan -
04-22-2013, 05:50 PM
Hm thats interesting U see...
quoting from autocar road test from 1984:
"capability of reving to no less than 7700 rpm"
But it might be true, my FSM says the tachometer accuracy is + /-200rpm
btw
I can also simulate this ...
I assume, therefore, that this is rather +200 rpm ?
  Digital speedometer on stock dashboard FanIsHere 0 1,803 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 3,340 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,596 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 6,140 03-24-2019 04:10 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 6,317 02-20-2016 11:48 AM
