Speedometer broke and check engine light
08-22-2026, 01:45 PM
| Speedometer broke and check engine light | |||
08-22-2026, 02:36 PM
(This post was last modified: 08-22-2026 02:36 PM by banpei.)
(08-22-2026 12:13 AM)sheppardpat47 Wrote: Thanks, do you know by any chance if it could also be the sensor on the gearbox that could be faulty or they don't break that often? I have no idea, I bought a cable (and fuel pump + filter, I want to replace it anyway and all the fuel lines)There is no sensor on the gearbox, it's just a cable going to the cabin. There is one other possibility, and that's the small plastic gear inside the gearbox that's worn out. But 95% of the time, it's the speedometer cable that's broken. This is the replacement gear: https://flos.ie/store/speedometer-gear-t...13105b7e4e (08-22-2026 01:45 PM)decryphe Wrote:Mine went further as well (even though it was about 165 on GPS), but there are cases where the ECU cuts out above 180km/h. Maybe that was only present on the kouki versions?(08-20-2026 09:39 PM)banpei Wrote: .. the 180km/h limiter ...I'm quite certain I've gone faster than that with my Japanese car and did not experience a fuel cut or anything. Certainly the needle on the dash has gone way past the end of the scale. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
08-22-2026, 05:18 PM
(08-22-2026 02:36 PM)banpei Wrote: There is no sensor on the gearbox, it's just a cable going to the cabin. There is one other possibility, and that's the small plastic gear inside the gearbox that's worn out. But 95% of the time, it's the speedometer cable that's broken. Good then I bought the cable, I hope it'll fix it! I know that the cable started making the needle "wiggle" a bit on lower speeds. (08-20-2026 09:39 PM)banpei Wrote: but there are cases where the ECU cuts out above 180km/h. Maybe that was only present on the kouki versions? Actually, mine cut at 194km/h GPS speed ! It was quite scary since it literally cut the fuel at that speed, it didn't go to the rev limiter. ![]() I did this last year when I was on the autobahn, after driving on the Nürburgring. 2007 - Daihatsu Sirion Sport 1.3 (daily) 2007 - Daihatsu Copen 1.3 (secondary car) 1985 - Toyota Sprinter Trueno AE86 2 door (antique car) -> For car pics, Instagram "@taiko_mobile"
08-22-2026, 10:08 PM
(This post was last modified: 08-22-2026 10:09 PM by banpei.)
That's quite interesting.
Actually, there is an interview in a 1990s book (the AE86 book) with one of the engineers who worked on the AE86. In that interview, he states that they calculated the live axle to become unsafe at speeds around 200km/h and they made the car top out at 190 with cat and 195 without. Now the interview doesn't say how they achieved that. But given that with a stock final drive (4.778 ) and gearbox (T50), the AE86 should theoretically top out at 210km/h at 7800rpm, it would suggest Toyota made sure you couldn't reach those speeds. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
08-22-2026, 11:25 PM
(08-22-2026 10:08 PM)banpei Wrote: That's quite interesting. To be honest, I wouldn't like to be in a car crash (even at low speed) with an AE86, it's literally a tin can. Do you remember that Chinese crash video of that stupid Volkswagen driver crashing into a red 3 door Levin in a touge? https://youtu.be/I-hiKWAaOLU?list=PLCV0Z...tn5aczWzLz 2007 - Daihatsu Sirion Sport 1.3 (daily) 2007 - Daihatsu Copen 1.3 (secondary car) 1985 - Toyota Sprinter Trueno AE86 2 door (antique car) -> For car pics, Instagram "@taiko_mobile"
08-23-2026, 08:49 AM
(08-22-2026 10:08 PM)banpei Wrote: That's quite interesting. My guess would be that they specced the gearing the way that it doesn't have enough hp to get to the revlimiter in 5th. The drag is simply to high for the 4age to overcome. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
08-23-2026, 11:52 AM
(08-22-2026 10:08 PM)banpei Wrote: Actually, there is an interview in a 1990s book (the AE86 book) [...]Okay, that's good to know. So I should probably get an uprated axle before autobahning with the M-factory longer fifth that's still awaiting install. Mostly looking forward to lower RPM at 120km/h. (08-22-2026 11:25 PM)sheppardpat47 Wrote: To be honest, I wouldn't like to be in a car crash (even at low speed) with an AE86, it's literally a tin can. Do you remember that Chinese crash video of that stupid Volkswagen driver crashing into a red 3 door Levin in a touge?Hadn't seen that before. Small overlap or even side impact in an old car is about the worst kind of impact you can have. Either way, absolutely unrelated: I just calculated I have to do 23.5kkm a year for the next 30 years to reach 868686km on the odo... Now I just need to figure out how to do that many kms a year |
08-23-2026, 01:44 PM
(08-23-2026 11:52 AM)decryphe Wrote:That's also why the FIA allowed the usage of a reinforced rear axle in Group A. Also, some of the cars participating in the 24h races (Le Mans / Spa / Nurburgring) featured oil coolers on the rear differential to keep the temperature down.(08-22-2026 10:08 PM)banpei Wrote: Actually, there is an interview in a 1990s book (the AE86 book) [...]Okay, that's good to know. So I should probably get an uprated axle before autobahning with the M-factory longer fifth that's still awaiting install. Mostly looking forward to lower RPM at 120km/h. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-11-2026, 11:30 PM
Welp. It was just the speedometer cable that was disconnected for whatever reason, seems to work fine now!
I bought one for nothing, heh. No more check engine light!
10-02-2026, 02:04 PM
is puretech joke on peugeot?
i havent talked here in a while. i forgot to check. peugeot 206 lover i love the ae86 two |
| ECON and PWR light troubleshooting | magpie | 3 | 4,621 |
07-18-2023 01:28 PM Last Post: banpei |
| PWR light issue and no brake fluid after winter storage | magpie | 10 | 7,955 |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 3,398 |
| Engine Check Light at High RPM | Super86 | 8 | 12,643 |
11-03-2014 11:03 AM Last Post: Super86 |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 11,101 |
![AEU86 AE86 - Speedometer broke and check engine light [Image: AEU86 AE86 - Speedometer broke and check engine light]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Speedometer broke and check engine light [Image: AEU86 AE86 - Speedometer broke and check engine light]](https://i.ibb.co/C3dg0D4K/brave-2026-08-22-17-17-38.png)
![AEU86 AE86 - Speedometer broke and check engine light [Image: AEU86 AE86 - Speedometer broke and check engine light]](https://i.ibb.co/996sSx47/805763379-28469333682697298-6755027537024722759-n.jpg)
