Some parts that i sell
07-27-2006, 10:46 AM
i get asked quite frequently what all parts do i sell
well i made a list took me a few hours to do so but i think it will probably help some one out who is looking for something basically i took all the posts of parts for sale i have up on club 4ag and combined them happy reading BTW all the prices are in USD New Parts for sale CLUTCHES TOYOTA 4AGE (200mm) starting at 295 4AGE (212MM) starting at 415 4AGZE starting at 369 4AGE for W58 Trans starting at 325 (200mm) 4AGE for W58 Trans starting at 425 (212mm) 3SGTE 90~95 SW20 Turbo starting at 375 7MGTE starting at 520 3TC 2 door 315 3TC 4 door 270 SCION TC Starting at 315 NISSAN KA (SOHC & DOHC) starting at 365, (DOUBLE DIAPHRAM NOW AVAIALABLE!) SR20DET starting at 375 (DOUBLE DIAPHRAM NOW AVAIALABLE!) CA18DET Starting at 311 RB25DET Double Diaphragm (TBA) MAZDA Miata 1.6 starting at 300 Miata 1.8 starting at 345 NA FC3S starting at 325 (zenki) 345 (kouki) Turbo II FC starting at 410 FD RX7 starting at 650 MISTUBISHI Gallant VR-4 starting at 350 EVO starting at 875 SUBARU WRX starting at 775 HONDA S2K starting at 850 Ford Focus starting at $550 TRANSMISSION REBUILD KIT TOYOTA 1985~87 COROLLA GTS RWD T50 TRANSMISSION 5MT 350 W55 TRANSMISSION 5MT 350 FLYWHEEL TOYOTA 4AGE 200MM 250 7AGE 200MM 250 DRIVESHAFT (1 PIECE LIGHT WEIGHT STEEL) TOYOTA 1985~87 COROLLA GTS RWD 350 BRAKE PADS TOYOTA 1985~87 COROLLA GTS RWD METALIC PADS FRONTS 45 REARS 45 MK3 SUPRA NA METALIC PADS FRONTS (TBA) REARS (TBA) MK3 SUPRA TURBO METALIC PADS FRONTS (TBA) REARS (TBA) MK4 SUPRA NA METALIC PADS FRONTS (TBA) REARS (TBA) MK4 SUPRA TURBO METALIC PADS FRONTS (TBA) REARS (TBA) 1985~89 MR2 METALIC PADS FRONTS (TBA) REARS (TBA) 91~96 MR2 METALIC PADS FRONTS (TBA) REARS (TBA) NISSAN 1989~97 240SX 4 LUG METALIC PADS FRONTS (TBA) REARS (TBA) 1989~97 240SX 5 LUG METALIC PADS FRONTS (TBA) REARS (TBA) 1989~97 300ZX NA METALIC PADS FRONTS (TBA) REARS (TBA) 1989~96 300ZX TURBO METALIC PADS FRONTS (TBA) REARS (TBA) BRAKE ROTORS TOYOTA 1985~87 COROLLA GTS RWD FRONTS 35 REARS 35 MK3 SUPRA NA FRONTS (TBA) REARS (TBA) MK3 SUPRA TURBO FRONTS (TBA) REARS (TBA) MK4 SUPRA NA FRONTS (TBA) REARS (TBA) MK4 SUPRA TURBO FRONTS (TBA) REARS (TBA) 1985~89 MR2 FRONTS (TBA) REARS (TBA) 91~96 MR2 FRONTS (TBA) REARS (TBA) NISSAN 1989~97 240SX 4 LUG FRONTS (TBA) REARS (TBA) 1989~97 240SX 5 LUG FRONTS (TBA) REARS (TBA) 1989~97 300ZX NA FRONTS (TBA) REARS (TBA) 1989~96 300ZX TURBO FRONTS (TBA) REARS (TBA) SHOCKS TOYOTA 1985~87 COROLLA GTS RWD TOKICO HTS FRONTS 275 REARS 275 TOKICO HP FRONTS 100 REARS 85 SPRINGS (TRD JAPAN) TOYOTA 1985~87 COROLLA GTS RWD FRONTS 155 (MANY DIFFRENT RATES AVAILABLE) REARS 155 (MANY DIFFRENT RATES AVAILABLE) WHEELS (SET OF 4 WHEELS) 4x114.3 PCD KONIG REWINGS (15x7 ZERO OFFSET) 500 SPORT MAX 002 (15X8 ZERO OFFSET) 425 VOLK TE37 (14X7 ZERO OFFSET) 1400 VOLK TE37 (15X7 ZERO OFFSET) 1600 TIRES (SET OF 4 TIRES) DUNLOP FM901'S 195/50 15 $299 DUNLOP FM901'S 195/55 15 $319 FALKEN ZIEX ??? FALKEN AZENIS ??? YOKOHAMA ES100 195/50 15 $334 JAPANESE OEM AE86 KOUKI TRUENO PARTS Kouki front Skin $430 Kouki front brackets (L+R) $134 Kouki front bumper lamps (L+R) $165 Kouki front Grill $57 Kouki emblem $29 Kouki Black limited Emblem $34 Kouki Rear skin $224 Kouki Rear Bumper Brackets $114 AE86 KOUKI LEVIN PARTS Kouki Levin hood OEM $450 Kouki levin fender R OEM $575 Kouki levin fender L OEM $250 Kouki levin front bumper OEM $250 Kouki levin Headlamp L $325 Kouki levin Headlamp R $325 Kouki Levin front bumper bracket L $75 Kouki Levin front bumper bracket R $75 Kouki Levin front bumper lamp L $100 Kouki Levin front bumper lamp R $100 Kouki Levin front grill $150 Kouki Levin corner lamp L $125 Kouki Levin corner lamp R $125 Kouki Levin fog lamp L $125 Kouki Levin fog lamp R $125 FRP Levin fenders $400 (pair) FRP levin Hood $400 CF levin fenders $550 (pair) CF levin hood $550 OEM PARTS 1985~87 COROLLA GTS RWD CLIMTAE CONTROL (STICKER ONLY) 15 CLOCK BEZEL 15 IGNITON CYCLINDER W/ 2 KEYS 90 FRONT CALIPER REBUILD KIT 20 REAR CALIPER REBUILD KIT 20 CAT BACK EXHAUST 120 INNER TIE RODS (MOOG) 100 OUTTER TIE RODS (MOOG) 100 TRANSMISSION MOUNT 100 CAT CONVERTER 125 EX MANIFOLD STUDS 6 EACH EX MANIFOLD NUTS 4 EACH TRD 1985~87 COROLLA GTS RWD HEAD GASKET 60 4~1 HEADERS 425 ENGINE MOUNTS (2 PIECES) 110 BUSHING KIT 375 SHIFT KNOB BALL TYPE 30 FRONT SWAY BAR 180 DISTRIBUTOR HEAT SHIELD 1985~87 COROLLA GTS RWD 45 SILICONE INTAKE HOSE 1985~87 COROLLA GTS RWD 55 USED PARTS FOR SALE 1985~87 COROLLA GTS RWD (4AGE) Drivers door glass 15 bucks each Passangers door glass 15 bucks each rear coupe glass 40 bucks each rear hatch glass 50 bucks each ZENKI LEVIN POP UP GRILL 100 FENDER LAMPS 10 (PER PAIR) TAIL LAMPS USA TYPE 15 EACH WATER PUMP REAR HOUSING 25 WATER LINES 20 THERMOSTAT NECK 10 UPPER RADIATOR PIPE 10 OPEN DIFFERENTIAL GEARS ZENKI AND KOUKI 25 OIL FILTER SANDWICH PLATE (FOR OIL COOLER) 25 ALTERNAOTR BRACKET 45 IGNITION CYCLIDER W/ KEY 25 AE101 IGNITOR 100 AE11 IGNITOR 100 CRANK PULLEY 75 TVIS BUTTERFLIES 50 STARTER 25 ALTERNATOR 50 BLUETOP CYCLINDER HEAD 50 T50 TRANSMISSION NO BELLHOUSING 75 ENGINE HARNESS 125 UNDERDASH HARNESS 125 REAR HARNESS 75 FUSE BOX/ALTERNATOR HARNESS W/ FUSE BOX 100 IGNITOR 25 DISTRIBUTOR 50 TIMING BELT GEAR 10 WATER PUMP PULLEY 25 INTAKE MANIFOLD 200 O/S 2MM THROTTLE BODY 100 REDTOP FUEL RAIL 75 CLUTCH HARD LINE 75 STRUT BARS 50 CIRCUT OPENEING RELAY 20 GAUGE CLUTSTER 50 SR5 GAUGE CLUSTER 10 FLYWHEEL (RESURFACED) 45 TO BEARING COLAR 10 CLUTCH FORK 10 EGR SETUP 100 HOOD 35 DOOR 35 MIRRORS 15 (EACH) SPEEDO CABLE 25 STEERING RACK 75 STEERING COLUMB 50 AIR FLOW METER 45 INJECTORS 10 EACH EGR BOLT 10 Thanks for looking Max *admin edit* just removed the post in wrong section bit in the titel. Max remove this edit when you wish, just to let you know I edited the titel for you [email protected] |
07-27-2006, 03:06 PM
Hey max,
hehe, well you are in the buy section while you are selling, and you are a commercial garage of sorts, so.. I'll transfer this to the commercial section and I'll see if I can give you full access there (with banpei on vacation I need to figure some things out he usually does ) But the rights are only for starting new threads sso...
07-27-2006, 10:40 PM
Max the mirrors are the electric-powered ones ?
AE86 FANATIC!!! |
07-27-2006, 11:25 PM
yea i have some extra POWER mirrors
most people dont like them though because they shake so badly thats why we like SR5 cheapie manual mirrors no shaking you eyeballs to death when you look to change lanes Max [email protected] |
07-28-2006, 12:01 PM
How much for powered and non-powered ones with shipping costs to GREECE?
AE86 FANATIC!!! |
07-28-2006, 01:39 PM
Hi,
TAIL LAMPS USA TYPE 15 EACH Could you post here some pictures about them? I'm interested in them if they are for the 2dr coupe. How much would be the shipping to Hungary? Thanks! |
07-28-2006, 02:23 PM
ali i have to see if i have an extra set
i am parting a car soon and i think it has power mirrors i would have to weigh them before i could give you a price qoute Sutter what year is your corolla? 84 85? like this? ![]() Max [email protected] |
07-28-2006, 02:55 PM
No Max, mine is a '87 USDM Coupe (Levin actually but only after a conversion).
![]() My tail lamps are the Type III, both is fine. It's only important that the shape is different like the one you linked. Thanks! |
07-28-2006, 10:50 PM
I am interesting in the ZENKI LEVIN POP UP GRILL. Can you send me a picture ?
Thanks ! ^^ |
07-31-2006, 03:06 PM
Max how much is shipping for 2 pairs of mirrors in Greece?
And with which way can i pay you? ( i dont have paypall ) Thanks, Nick |
| Sell AE86 Wheels | JonnyAE86 | 1 | 6,225 |
05-22-2007 08:54 PM Last Post: JonnyAE86 |
| Sell - Brand New AE86 Rare | JonnyAE86 | 23 | 29,033 |
05-22-2007 12:25 PM Last Post: Mux213 |
| Sell - AE85 Engine 3A | JonnyAE86 | 1 | 4,200 |
04-26-2007 05:04 AM Last Post: JonnyAE86 |
| Sell - Trueno Interior | JonnyAE86 | 1 | 4,212 |
04-26-2007 05:03 AM Last Post: JonnyAE86 |
| Some aftermarket parts FS | ke86 | 48 | 49,791 |
03-21-2007 03:17 AM Last Post: ke86 |
![AEU86 AE86 - Some parts that i sell [Image: AEU86 AE86 - Some parts that i sell]](http://img.photobucket.com/albums/v375/Max_Misawa/IMG_1067.jpg)
![AEU86 AE86 - Some parts that i sell [Image: AEU86 AE86 - Some parts that i sell]](http://www.billzilla.org/ae86tail.jpg)
