Some engine, brake and suspension DIY components.
01-20-2007, 09:36 PM
Post: #61
Sorry to skip the dollar sign ($) before 180.
The prices are in USD, there can be minor changes (up to 10EU) just for anodising (with/without colouring). Already built the 25mm set, cost was 150EU anodised (maybe USD/EUR ratio was little different while ago too, didn't record it).
04-05-2007, 10:02 PM
Post: #62
Interested in some 25mm and 15mm spacers.
And a set RCA's.
How fast could you make them?
Thanks! Smile
04-06-2007, 09:29 AM
Post: #63
25mm and 15mm spacers - that means spacers 4X114mm PCD without studs etc. - correct ?
04-06-2007, 11:06 AM
Post: #64
Yes 4x114,3 for the hachi.
I was actually after the bolt on type.
Like these: [Image: AEU86 AE86 - Some engine, brake and susp...omponents.]
04-06-2007, 11:15 AM
Post: #65
jea how much would be those in 25mm?
04-06-2007, 11:19 AM
Post: #66
Bubble_Drift, on your picture I see wheel adapters (not spacers) - these cannot be produced with 15mm thickness. Spacers need longer studs, adapters use their own studs. Unfortunately stock AE86 studs will work with very thin adapters - ~5-6mm thickness.
04-06-2007, 11:25 AM
Post: #67
wow talk about coincidences!!! Some guy who spent the past two years or so improoving his Fiat Coupe 2.0 turbo, just crashed it on his maiden voyage..
Reason: broken off adapter - 4 to 5 lugs. the adapter spacer was 20mm, but he thinned it to 13mm so he wouldnt have clearance problems.. spacer broke off at 130kph in fast corner..
what a shame.. something you pour your heart into... hope this never happens to any of you people..
so the adapter was either to thin or there was some casting fault / imperfections in the material.. i guess go with 25mms...
04-06-2007, 01:04 PM
Post: #68
jamiemirror Wrote:Bubble_Drift, on your picture I see wheel adapters (not spacers) - these cannot be produced with 15mm thickness. Spacers need longer studs, adapters use their own studs. Unfortunately stock AE86 studs will work with very thin adapters - ~5-6mm thickness.
Aha.. I see.
Well, how much for a set of 4x 25mm adapters and a pair of RCA's then?
Do you make adjustable panrods btw?
04-11-2007, 09:35 PM
Post: #69
Set (4) adapters $180 (~138EU) including screws and pressed studs.
RCA (pair) 40EU including bolts.
No, I just modify stock panhard rod using ready set of components (for example you can see CJ's project, he made modification himself using the same bolt&screws "kit"). In fact maybe adj. rod and 4-link rear arms will be reasonable to manufacture - I will think about that Cool
04-13-2007, 02:38 AM
Post: #70
what about some NCRA or strut rods(caster rods)?
  AJPS.com.au - - STEERING LOCK SPACERS and REAR brake upgrade AJPS 5 15,779 04-30-2014 05:10 AM
Last Post: AJPS
  Track and road brake kits ep71 12 18,696 09-17-2012 10:28 AM
Last Post: ep71
  Speed Industries: GReddy Sale, only suspension and brake kit speed-inc 28 30,329 04-24-2008 08:08 PM
Last Post: speed-inc
  BREAKING AE86 ENGINE GEAR BOX LONG CHAMPS SUSPENSION ALL ziggy 33 34,161 12-31-2007 09:26 PM
Last Post: Conrad
