Smokey 20V
12-09-2015, 09:46 AM
Smokey 20V
(12-01-2015 02:42 PM)pack Wrote: [ -> ]I see smoke..... the oil level went from high to almost dry in 400kms... Please don't bother with the seals. No stem seals at all + the worst valve guide clearance in the world would not = a liter, let alone 2, in 400kms!!!!! So what! |
12-09-2015, 10:32 AM
(This post was last modified: 12-09-2015 05:57 PM by d3nso.)
Smokey 20V
Yes no bad valve seal gives you 1l+ consumption alone sounds hard but your rings are smoked. Had the same Problem on a friends honda engine he also thought it where the seals I told them it's the rings and I was right in the end
12-09-2015, 12:09 PM
Smokey 20V
Yeah it is piston rings.... My rear bumper is filled with grease from the oil......
12-11-2015, 03:56 PM
Smokey 20V
(12-09-2015 12:09 PM)pack Wrote: [ -> ]Yeah it is piston rings.... My rear bumper is filled with grease from the oil...... "Now, me and the mad scientist got to rip apart the block... and replace the piston rings you fried." Sorry....too soon?
12-11-2015, 05:11 PM
Smokey 20V
(12-11-2015 03:56 PM)mad.matt Wrote: [ -> ](12-09-2015 12:09 PM)pack Wrote: [ -> ]Yeah it is piston rings.... My rear bumper is filled with grease from the oil...... I'm not sure if i understood your post... LOL But yeah basically i will rebuild my engine now.... I'm aiming at TRD - engine bearings ARP bolts all around Supertech valve seals OEM piston rings And.... basically this is it... |
12-11-2015, 07:13 PM
Smokey 20V
Make sure you get the right valve seals from Supertech as they do 2 sizes. One for the OEM valve guides and slightly slimmer ones for their own guides to suit the dual spring setup they offer.
AE86 ex-daily |
12-11-2015, 07:39 PM
Smokey 20V
I noticed that when i was reading about the supertech seals.....
gon maybe has the references i need for the seals... ![]()
12-11-2015, 07:58 PM
(This post was last modified: 12-11-2015 08:02 PM by isac.)
| Smokey 20V | |||
12-14-2015, 09:28 AM
Smokey 20V
https://www.supertechperformance.com/s67...02&em=5593
I bought mine in uk through these guys .... [email protected] |
12-14-2015, 11:46 AM
Smokey 20V
thanks
| Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 7,165 |
09-15-2013 01:08 AM Last Post: jondee86 |
| 20v bt swap to ae86 (20v or 16v flywheel????) | kid | 10 | 20,075 |
12-08-2007 04:09 PM Last Post: Jan Pedersen |
