Smokey 20V
12-09-2015, 09:46 AM
Smokey 20V
(12-01-2015 02:42 PM)pack Wrote: I see smoke..... the oil level went from high to almost dry in 400kms... Please don't bother with the seals. No stem seals at all + the worst valve guide clearance in the world would not = a liter, let alone 2, in 400kms!!!!! So what! |
12-09-2015, 10:32 AM
(This post was last modified: 12-09-2015 05:57 PM by d3nso.)
Smokey 20V
Yes no bad valve seal gives you 1l+ consumption alone sounds hard but your rings are smoked. Had the same Problem on a friends honda engine he also thought it where the seals I told them it's the rings and I was right in the end
12-09-2015, 12:09 PM
Smokey 20V
Yeah it is piston rings.... My rear bumper is filled with grease from the oil......
12-11-2015, 03:56 PM
| Smokey 20V | |||
12-11-2015, 05:11 PM
Smokey 20V
(12-11-2015 03:56 PM)mad.matt Wrote:(12-09-2015 12:09 PM)pack Wrote: Yeah it is piston rings.... My rear bumper is filled with grease from the oil...... I'm not sure if i understood your post... LOL But yeah basically i will rebuild my engine now.... I'm aiming at TRD - engine bearings ARP bolts all around Supertech valve seals OEM piston rings And.... basically this is it... |
12-11-2015, 07:13 PM
Smokey 20V
Make sure you get the right valve seals from Supertech as they do 2 sizes. One for the OEM valve guides and slightly slimmer ones for their own guides to suit the dual spring setup they offer.
AE86 ex-daily |
12-11-2015, 07:39 PM
Smokey 20V
I noticed that when i was reading about the supertech seals.....
gon maybe has the references i need for the seals... ![]()
12-11-2015, 07:58 PM
(This post was last modified: 12-11-2015 08:02 PM by isac.)
| Smokey 20V | |||
12-14-2015, 09:28 AM
Smokey 20V
https://www.supertechperformance.com/s67...02&em=5593
I bought mine in uk through these guys .... [email protected] |
12-14-2015, 11:46 AM
Smokey 20V
thanks
| Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 6,380 |
09-15-2013 01:08 AM Last Post: jondee86 |
| 20v bt swap to ae86 (20v or 16v flywheel????) | kid | 10 | 17,956 |
12-08-2007 04:09 PM Last Post: Jan Pedersen |
