Smallport coil
08-11-2022, 08:24 PM
Smallport coil
Does anyone know if the smallport coil is a direct replacement
for an AE86 coil? I'd like to use one as l'm using a smallport distributor which uses a cap with the thinner leads. An analogue brain in a digital World |
08-12-2022, 09:43 AM
Smallport coil
I'm a bit confused. If you are using the smallport distributor you should also be using the smallport ECU since it runs a different ignition system
to the AE86 (VAST vs ESA). If that is the case I would assume you would also need the matching igniter for that system, making the point a bit moot. So what's your setup like? FWIW, a coil is a pretty simple thing.. you could probably get away with mixing and matching it. From a club4ag smallport swap article: The coil just operates on a pulse from the igniter and would be interchangeable if not for the connector to the igniter (directly linked with a ring connector v. through a harness connector), which is an easy fix with some mild rewiring if you don’t have a matching set. https://club4ag.com/forums/viewtopic.php?t=12595 FABRICA MI DIEM, PVNC! |
08-12-2022, 11:03 AM
Smallport coil
I'm using Freedom ecu that allows different configurations, l was quite
surprised to find the engine runs the same with any 16v distributor. From a wiring perspective l guess the coils are the same? An analogue brain in a digital World |
| Coil charge time | totta Crolla | 0 | 1,025 |
01-23-2026 07:27 AM Last Post: totta Crolla |
| Smallport inlet manifold | totta Crolla | 6 | 6,525 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| How to test coil with igniter | DJexor | 2 | 10,959 |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 9,685 |
05-24-2017 09:24 PM Last Post: krullibull |
| Smallport Fuel Rail | Alex170984 | 2 | 6,604 |
11-19-2016 08:44 PM Last Post: Alex170984 |
