Smallport coil
08-11-2022, 08:24 PM
Smallport coil
Does anyone know if the smallport coil is a direct replacement
for an AE86 coil?
I'd like to use one as l'm using a smallport distributor which uses a
cap with the thinner leads.
08-12-2022, 09:43 AM
Smallport coil
I'm a bit confused. If you are using the smallport distributor you should also be using the smallport ECU since it runs a different ignition system
to the AE86 (VAST vs ESA). If that is the case I would assume you would also need the matching igniter for that system, making the point a bit moot.
So what's your setup like?
FWIW, a coil is a pretty simple thing.. you could probably get away with mixing and matching it.
From a club4ag smallport swap article:
The coil just operates on a pulse from the igniter and would be interchangeable if not for the connector to the igniter (directly linked with a ring connector v. through a harness connector), which is an easy fix with some mild rewiring if you don’t have a matching set.
https://club4ag.com/forums/viewtopic.php?t=12595
08-12-2022, 11:03 AM
Smallport coil
I'm using Freedom ecu that allows different configurations, l was quite
surprised to find the engine runs the same with any 16v distributor.
From a wiring perspective l guess the coils are the same?
  Coil charge time totta Crolla 0 779 01-23-2026 07:27 AM
Last Post: totta Crolla
  Smallport inlet manifold totta Crolla 6 5,993 01-17-2022 05:14 PM
Last Post: oldeskewltoy
  How to test coil with igniter DJexor 2 10,524 03-22-2018 10:01 AM
Last Post: Project D
  4A-GTE 7-rib smallport nyberrg 5 9,163 05-24-2017 09:24 PM
Last Post: krullibull
  Smallport Fuel Rail Alex170984 2 6,291 11-19-2016 08:44 PM
Last Post: Alex170984
