Smallport Head swap
06-08-2016, 09:54 AM
Smallport Head swap
Hi,
Is the bigport fuel rail not interchangeable with the smallport head? cheers |
06-08-2016, 10:06 AM
Smallport Head swap
No. The injector spacing is different.
Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
06-08-2016, 11:16 AM
Smallport Head swap
Got a spare rail?
06-08-2016, 12:35 PM
Smallport Head swap
Is the distributor the same?
06-08-2016, 12:42 PM
Smallport Head swap
No not the same
06-08-2016, 01:16 PM
Smallport Head swap
Can I use the bigport dizzy though?
06-08-2016, 01:47 PM
Smallport Head swap
Yes you should be able to use the bigport dizzy.
06-08-2016, 03:49 PM
(This post was last modified: 06-08-2016 03:50 PM by Bean.)
Smallport Head swap
Just to confirm, fuel rail is not interchangeable the dizzy is.
AE86 ex-daily |
06-08-2016, 07:31 PM
Smallport Head swap
Are you sure,im pretty sure something was different?
they fitted but something inside was not the same if i remember correct |
06-09-2016, 12:11 PM
Smallport Head swap
The AFM dizzy is the same (except the connectors, but it can be changed easily) The MAP smallport distributor is a unique thing for me, so its not compatible with the olders!
| Smallport coil | totta Crolla | 2 | 3,929 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| Smallport inlet manifold | totta Crolla | 6 | 6,265 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 9,385 |
05-24-2017 09:24 PM Last Post: krullibull |
| Smallport Fuel Rail | Alex170984 | 2 | 6,473 |
11-19-2016 08:44 PM Last Post: Alex170984 |
| 4A-GE: Bigport with smallport fuel injection | nyberrg | 7 | 15,788 |
06-13-2015 05:00 PM Last Post: nyberrg |
