Small Port Swap
11-20-2016, 02:07 AM
Small Port Swap
Hi,
I am going to be embarking upon a bigport to mongrel smallport swap. I am using small port pistons, but bigport crank and rods, but also the smallport head and inlet manifold but retaining my bigport ECU. I have read articles and threads about a flat spot occurring at 2k rpm when people swap to smallport from bigport and it's down to the TVIS being deleted. I have jammed my TVIS open on my current engine because it is restrictive for my high lift cams, so in essence, i have deleted the TVIS but haven't physically removed the butterflies or plate. I was under the impression due to my cam setup that this apparent flat spot would be there if I was running standard cams, but because I am not, i haven't noticed it...I thought this would be the same when I swap over to the small port head and inlet manifold. Has anyone been victim of this flat spot? Cheers |
11-21-2016, 01:46 PM
Small Port Swap
I have since seen conflicting threads saying it's a load of rubbish.
| 4AGE Big port head failure | Blaze0010 | 3 | 1,772 |
01-23-2026 03:35 PM Last Post: totta Crolla |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 10,132 |
| Small Port 10.3 Pistons | Alex170984 | 1 | 6,202 |
| Small question about wheels | Vortrex | 6 | 11,872 |
07-19-2013 01:43 PM Last Post: DJexor |
| 4age intake side (port) dimensions | Uzelac | 15 | 43,319 |
03-03-2011 12:43 AM Last Post: Uzelac |
