Silvertop : Inlet valve stuck!!
10-02-2008, 02:35 PM
I have installed a silvertop, Had been driving it briefly, I drove it down the road and it started to misfire, it went off a cylinder, sounded like a pluglead went bad. Put a compression check on it, cylinder 3 has no compression, took the rocker cover off, centre inlet valve jammed down. Anyone heard of this before, or know what to do next?
Cheers
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
10-02-2008, 05:29 PM
hi,i had the same thing with my blacktop engine,just try to make it lose again with a little bit of oil or something,it worked fine for me.
i think that they cleaned the engine and there was some water in the engine
[Image: AEU86 AE86 - Silvertop : Inlet valve stuck!!]
10-15-2008, 03:33 PM
I removed the inlet cam and managed to get the follower off the valve, oh dear, collets missing, valve spring in 2, valve bent. Need to remove the head to see if the piston is damaged.
Anyone have part numbers for silvertop parts, all parts listed above.
Cheers
Ivan
10-15-2008, 05:24 PM
AE111 20V Part Numbers
11115-16111 GASKET, CYLINDER HEAD 01.05.1995-01.08.2000 4AGE..AE111 *Blacktop 20V Headgasket*
13540-16010 TENSIONER ASSY, CHAIN, NO.1 01.05.1995-01.08.2000 4AGE..AE111
13568-19185 BELT, TIMING 01.05.1995-01.08.2000 4AGE..AE111
19000-1A400 ENGINE ASSY, PARTIAL 01.05.1995-01.08.2000 4AGE..AE111 ***BLACKTOP LONG MOTOR***
90919-01178 PLUG, SPARK 01.05.1995-01.08.2000 4AGE..AE111;PK20R11
90919-01179 PLUG, SPARK 01.05.1995-01.08.2000 4AGE..AE111;BKR6EP11
90919-21592 CORD SET, COIL AND SPARK, W/RESISTIVE 01.05.1995-01.08.2000 4AGE..AE111
90919-02197 COIL ASSY, IGNITION 01.05.1995-01.08.2000 4AGE..AE111
04111-16330 GASKET KIT, ENGINE OVERHAUL 01.05.1995-01.08.2000 4AGE..AE111
15100-19045 PUMP ASSY, OIL 01.05.1995-01.08.2000 4AGE..AE111
16100-19285 PUMP ASSY, WATER 01.05.1995-01.08.2000 4AGE..AE111
13101-16220-01 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;STD,MARK 1
13101-16220-02 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;STD,MARK 2
13101-16220-03 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;STD,MARK 3
13103-16220 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;O/S 0.50
13405-16110 FLYWHEEL SUB-ASSY 01.05.1995-01.08.2000 4AGE..AE111..MTM
13401-16020 CRANKSHAFT 01.05.1995-01.08.2000 4AGE..AE111
17700-1A020 CLEANER ASSY, AIR 01.04.1997-01.08.2000 4AGE..AE111
28100-16170 STARTER ASSY 01.04.1997-01.08.2000 4AGE..AE111..6F;12V 1.0KW
19100-16270 DISTRIBUTOR ASSY 01.05.1995-01.08.2000 4AGE..AE111
19101-16010 CAP SUB-ASSY, DISTRIBUTOR 01.05.1995-01.08.2000 4AGE..AE111
22210-16763 BODY ASSY, THROTTLE 01.10.1998-01.08.2000 4AGE..AE111
30300-1A260 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZR ***6-speed***
30300-1A250 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZG..6F
41301-12041 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE11#..MTM..(BZG,FZ,XZ)
41301-12190 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE111..MTM..(BZR,BZV) ***LSD????***
33530-12700 LEVER ASSY, SHIFT (FOR FLOOR SHIFT) 01.04.1997-01.08.2000 AE111..6F
22270-16070 VALVE ASSY, IDLE SPEED CONTROL(FOR THLOTTLE BODY) 01.05.1995-01.08.2000 4AGE..AE111
89661-1A860 COMPUTER, ENGINE CONTROL 01.04.1997-01.08.2000 AE111..6F
82121-1N761 WIRE, ENGINE 01.04.1998-01.08.2000 AE111..6F
89420-12140 SENSOR ASSY, VACUUM (FOR E.F.I.) 01.05.1995-01.08.2000 AE111..BZG,BZR,BZV
83420-20040 GAGE ASSY, WATER TEMPERATURE SENDER 01.05.1996-01.08.2000 AE11#
89428-12160 SWITCH, TEMPERATURE DETECT, NO.2 01.05.1995-01.08.2000 AE11#
89465-19685 SENSOR, OXYGEN 01.05.1995-01.08.2000 AE111..BZG,BZR,BZV
89615-22050 SENSOR, KNOCK CONTROL 01.09.1998-01.08.2000 AE11#;TOYOTA
hmmz only have from the blacktop. Though I think with the engine code the dealer should be able to find the right ones!
10-15-2008, 05:29 PM
http://www.toyodiy.com/
the online epc Wink
10-19-2008, 02:47 AM
Cheers guys, that helps, can't believe the detail the website goes into. I will hopefully get the head off in the next day or so and get it back on the road.
Thanks again.
Ivan
10-19-2008, 10:59 AM
The Doctor Wrote:http://www.toyodiy.com/
the online epc Wink
Hey, that's nice! So I could have saved myself the trouble of installing those EPC cd's when I was recently working on a coleagues Carina.
10-19-2008, 01:32 PM
EE80Liftback Wrote:Hey, that's nice! So I could have saved myself the trouble of installing those EPC cd's when I was recently working on a coleagues Carina.
By chance an A60 Carina? Dumb question
10-19-2008, 02:52 PM
No, sorry it was a 90's Carina E.
  4A-GE valve shim disintegrated DaLanZhu 2 3,273 04-30-2025 12:54 PM
Last Post: DaLanZhu
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 9,445 05-26-2024 07:40 PM
Last Post: totta Crolla
  4AGE Valve Buckets Scored Steller Engineering 2 3,204 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 4,354 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 4,970 05-25-2022 10:24 PM
