Silvertop : Inlet valve stuck!!
10-02-2008, 02:35 PM
I have installed a silvertop, Had been driving it briefly, I drove it down the road and it started to misfire, it went off a cylinder, sounded like a pluglead went bad. Put a compression check on it, cylinder 3 has no compression, took the rocker cover off, centre inlet valve jammed down. Anyone heard of this before, or know what to do next?
Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
10-02-2008, 05:29 PM
hi,i had the same thing with my blacktop engine,just try to make it lose again with a little bit of oil or something,it worked fine for me.
i think that they cleaned the engine and there was some water in the engine ![]() sr86 completed!!........漂うことのマスター!!!! |
10-15-2008, 03:33 PM
I removed the inlet cam and managed to get the follower off the valve, oh dear, collets missing, valve spring in 2, valve bent. Need to remove the head to see if the piston is damaged.
Anyone have part numbers for silvertop parts, all parts listed above. Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
10-15-2008, 05:24 PM
AE111 20V Part Numbers
11115-16111 GASKET, CYLINDER HEAD 01.05.1995-01.08.2000 4AGE..AE111 *Blacktop 20V Headgasket* 13540-16010 TENSIONER ASSY, CHAIN, NO.1 01.05.1995-01.08.2000 4AGE..AE111 13568-19185 BELT, TIMING 01.05.1995-01.08.2000 4AGE..AE111 19000-1A400 ENGINE ASSY, PARTIAL 01.05.1995-01.08.2000 4AGE..AE111 ***BLACKTOP LONG MOTOR*** 90919-01178 PLUG, SPARK 01.05.1995-01.08.2000 4AGE..AE111;PK20R11 90919-01179 PLUG, SPARK 01.05.1995-01.08.2000 4AGE..AE111;BKR6EP11 90919-21592 CORD SET, COIL AND SPARK, W/RESISTIVE 01.05.1995-01.08.2000 4AGE..AE111 90919-02197 COIL ASSY, IGNITION 01.05.1995-01.08.2000 4AGE..AE111 04111-16330 GASKET KIT, ENGINE OVERHAUL 01.05.1995-01.08.2000 4AGE..AE111 15100-19045 PUMP ASSY, OIL 01.05.1995-01.08.2000 4AGE..AE111 16100-19285 PUMP ASSY, WATER 01.05.1995-01.08.2000 4AGE..AE111 13101-16220-01 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;STD,MARK 1 13101-16220-02 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;STD,MARK 2 13101-16220-03 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;STD,MARK 3 13103-16220 PISTON SUB-ASSY, W/PIN 01.05.1995-01.08.2000 4AGE..AE111;O/S 0.50 13405-16110 FLYWHEEL SUB-ASSY 01.05.1995-01.08.2000 4AGE..AE111..MTM 13401-16020 CRANKSHAFT 01.05.1995-01.08.2000 4AGE..AE111 17700-1A020 CLEANER ASSY, AIR 01.04.1997-01.08.2000 4AGE..AE111 28100-16170 STARTER ASSY 01.04.1997-01.08.2000 4AGE..AE111..6F;12V 1.0KW 19100-16270 DISTRIBUTOR ASSY 01.05.1995-01.08.2000 4AGE..AE111 19101-16010 CAP SUB-ASSY, DISTRIBUTOR 01.05.1995-01.08.2000 4AGE..AE111 22210-16763 BODY ASSY, THROTTLE 01.10.1998-01.08.2000 4AGE..AE111 30300-1A260 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZR ***6-speed*** 30300-1A250 TRANSAXLE ASSY, MANUAL 01.04.1997-01.08.2000 AE111..BZG..6F 41301-12041 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE11#..MTM..(BZG,FZ,XZ) 41301-12190 CASE, FRONT DIFFERENTIAL 01.05.1995-01.08.2000 AE111..MTM..(BZR,BZV) ***LSD????*** 33530-12700 LEVER ASSY, SHIFT (FOR FLOOR SHIFT) 01.04.1997-01.08.2000 AE111..6F 22270-16070 VALVE ASSY, IDLE SPEED CONTROL(FOR THLOTTLE BODY) 01.05.1995-01.08.2000 4AGE..AE111 89661-1A860 COMPUTER, ENGINE CONTROL 01.04.1997-01.08.2000 AE111..6F 82121-1N761 WIRE, ENGINE 01.04.1998-01.08.2000 AE111..6F 89420-12140 SENSOR ASSY, VACUUM (FOR E.F.I.) 01.05.1995-01.08.2000 AE111..BZG,BZR,BZV 83420-20040 GAGE ASSY, WATER TEMPERATURE SENDER 01.05.1996-01.08.2000 AE11# 89428-12160 SWITCH, TEMPERATURE DETECT, NO.2 01.05.1995-01.08.2000 AE11# 89465-19685 SENSOR, OXYGEN 01.05.1995-01.08.2000 AE111..BZG,BZR,BZV 89615-22050 SENSOR, KNOCK CONTROL 01.09.1998-01.08.2000 AE11#;TOYOTA hmmz only have from the blacktop. Though I think with the engine code the dealer should be able to find the right ones! Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-15-2008, 05:29 PM
10-19-2008, 02:47 AM
Cheers guys, that helps, can't believe the detail the website goes into. I will hopefully get the head off in the next day or so and get it back on the road.
Thanks again. Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
10-19-2008, 10:59 AM
The Doctor Wrote:http://www.toyodiy.com/Hey, that's nice! So I could have saved myself the trouble of installing those EPC cd's when I was recently working on a coleagues Carina. |
10-19-2008, 01:32 PM
EE80Liftback Wrote:Hey, that's nice! So I could have saved myself the trouble of installing those EPC cd's when I was recently working on a coleagues Carina.By chance an A60 Carina?
10-19-2008, 02:52 PM
No, sorry it was a 90's Carina E.
| 4A-GE valve shim disintegrated | DaLanZhu | 2 | 3,324 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 9,549 |
| 4AGE Valve Buckets Scored | Steller Engineering | 2 | 3,262 |
| 20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 4,413 |
| HKS valve springs | totta Crolla | 3 | 5,021 |
![AEU86 AE86 - Silvertop : Inlet valve stuck!! [Image: AEU86 AE86 - Silvertop : Inlet valve stuck!!]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
![AEU86 AE86 - Silvertop : Inlet valve stuck!! [Image: AEU86 AE86 - Silvertop : Inlet valve stuck!!]](https://www.aeu86.org/sticker-banner-468.gif)
