SPRINGS FOR AE86
06-06-2007, 09:34 AM
SPRINGS FOR AE86
Double post
06-06-2007, 09:47 AM
SPRINGS FOR AE86
Since I am in the process of looking for better springs, I just
happen to have a whole bunch of measurements handy Front eyebrow height = 300 (centre of hub to wheel arch) Rear eyebrow height = 290 Front body seam to ground = 130 (at jacking point) Rear body seam to ground = 135 [img name=]http://www.aeu86.org/files/84/84ae86gts_554.jpg[/img] Wheels are 13 x7 with negative 7 offset from memory. The springs are Jamex (Asian I believe) which give an acceptable ride height, but they are too soft for even moderately spirited driving. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
06-20-2007, 11:20 AM
SPRINGS FOR AE86
I have edited the first post, so i dont open a new topic since there's some good info here already. Please take a look.
Cheers!
06-20-2007, 06:02 PM
SPRINGS FOR AE86
![]() Custom wound springs ride height = Stock(+ or - 10 mm) rates are 4.5 kg/mm front with 3.0 kg/mm rear (stock USA GTS spring rates are 1.9kg/mm front and 2.2 kg/mm rear) Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-29-2007, 03:52 PM
SPRINGS FOR AE86
Can anybody explain what 6,5kg means .
what's the stock spring features. I need much stiffer spring at front but doesn't really know what specifications (meaning about kg/mm)I should look about. FILH Filh Save the RWD cars |
08-29-2007, 04:04 PM
SPRINGS FOR AE86
6.5kg/mm means that the compression of 6.5kg (pressure) per MM goes.
so 5mm damping needs around 32.5kg Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
08-30-2007, 10:48 PM
SPRINGS FOR AE86
So the highest Xkg/mm equal to very stiff springs ?
thanks for the explanation. filh Filh Save the RWD cars |
08-31-2007, 06:20 PM
SPRINGS FOR AE86
yes the figure says how much force is needed to squish the springs for 1 mm. naturally the springs that need 8kgs to be squished for 1mm are stiffer than the springs that only need say 4 kgs for that 1 mm.
| HKS valve springs | totta Crolla | 3 | 4,973 |
| Springs from other vehicles?? | FanIsHere | 16 | 21,766 |
05-17-2016 09:12 AM Last Post: FanIsHere |
| 3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 8,737 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
| Valve springs length | Vil | 4 | 8,100 |
04-04-2013 07:41 PM Last Post: oldeskewltoy |
| Maybe problem with TRD shock absorber and springs | Mattolo | 22 | 29,513 |
10-15-2011 07:40 PM Last Post: zenki |
![AEU86 AE86 - SPRINGS FOR AE86 [Image: AEU86 AE86 - SPRINGS FOR AE86]](http://i79.photobucket.com/albums/j143/oldeskewltoy/Danrolling.jpg)
