S13 Front brakes in AE86 rear
01-14-2014, 08:13 PM
Some new pics..
Cheated on my いたずらな女の子 and now I can't get enough of her.. |
01-14-2014, 08:20 PM
maybe start with bigger discs like said above,its an cheap update unlike the s13 front brakes in the rear i think.
seems weird that rear doenst lock,even with stock setup i had plenty of luck. Maybe its another problem? |
01-14-2014, 08:45 PM
Mine also has no problem locking up the rear wheels with stock setup.
01-14-2014, 08:52 PM
It might be the rear discs being too worn out and using crappy pads.. But whatever it is unfortunately even with a hydro setup it doesn't lock up.
![]() I was looking at getting steel braided lines and new discs and using mintex pads but now I'm thinking given that I have the S13 parts lying around I'd use it in one go. Its cheaper in the long run. Even to use larger discs I need to use the AJPS adapter plate or make one.. I'm thinking to do both 3 things in one go. Go for large discs, go for larger calipers and go even larger than S13 rear brakes which is whats done normally. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
01-14-2014, 09:23 PM
Your current setup being completely worn out might be the reason. Another thing to check before starting to do any changes is insuring that the system is free of air. Hydro's are a bit tricky to bleed properly and thoroughly.
AE86 ex-daily |
01-20-2014, 04:17 PM
A small update.
The workshop started on getting the S13 front brakes on the 86 rear. Discs put on and hoping to get the bracket done soon. As I'm using 16" wheels the caliper should clear the wheels easily Cheated on my いたずらな女の子 and now I can't get enough of her.. |
01-20-2014, 04:19 PM
Thanks Bean Bandit for your help in this matter..
Note that as I don't have cable handbrake front brakes aren't a big concern. For you guys this may not work. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
01-25-2014, 05:52 AM
S13 Front brake discs and calipers are now on the car.....
![]() ![]() Its test drive time now ![]() Cheated on my いたずらな女の子 and now I can't get enough of her.. |
01-25-2014, 12:09 PM
How about something like that?
![]() 1 caliper - conventional brake system 1 caliper - for hydro-ebrake My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD |
01-25-2014, 12:16 PM
Yeah this might be the perfect solution,i know at least 1 person here in rally runs this setup and he is happy with it.
Rear brakes | totta Crolla | 0 | 1,382 |
02-03-2023 12:54 PM Last Post: totta Crolla |
Switching diffs for disc brakes? | trippin | 6 | 3,982 |
07-08-2022 03:35 AM Last Post: trippin |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 4,237 |
S13 Front conversion help (S14/S15?) | 4000GT | 6 | 10,012 |
11-21-2014 06:55 PM Last Post: asyrigos |
SR20DET (S13) gearbox shifting issues in AE86 | heshan | 8 | 12,459 |
07-22-2014 01:07 PM Last Post: heshan |
