11-23-2009, 12:40 PM
Post: #241
Lennert,
Try this: Remove the following fuses: -STOP -HEATER (if you have it) -DOME -HORN -RADIO -EFI Pull the following relays out: -DEFOGGER -TAILLIGHT -HEADLIGHT Those are about all of the circuits that are connected to 12V that do not go through the ignition switch. See if the buzzing stops.. then start plugging them back in one by one until you find the one that causes you problems. FABRICA MI DIEM, PVNC! |
11-23-2009, 12:42 PM
Post: #242
Hey bean, thx for the offer and now I don't have a day off
![]() The sound comes from a relais (sorry didn't tell that sooner) at the fuse box near the clutch pedal. I changed the box over from a spare which I had laying around with other relais (same type but diffrent ones) and didn't help. For the wierd reaspn. If I plug in an ECU from an AE82GT or from an kouki AE86 I don't get the wierd sound. I don't get an engine checklight either. I also changed the cluster unit for another one and didn't didn't do much. My own guess is that I used the wrong engine wireloom. But that seems nearly impossible because the zenki and kouki have diffrent diagnostic plugs. It might be possible for me to change the inner loom and the engine loom but I need to check my stock. If anyone has a good guess...... Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-23-2009, 12:50 PM
Post: #243
I do have an MAP engine loom with me but I wouldn't think this will help a lot... IMHO it's easier to try and find the cause... I'll do some head scratching and see where it leads me (might be able to dublicate your fault on my car... but I brought very little tools so could take a while)
![]() IMHO the box that does the sound isn't the one at fault but another one, remotely connected to it... AE86 ex-daily |
11-23-2009, 02:31 PM
Post: #244
could you check your engine fuse box ? is it the same as mine ? I can replace that one.
11-23-2009, 03:07 PM
Post: #245
ik heb bijna het zelfde probleem gehad.
het lag bij mij aan een kapotte zekering + een contact slot wat niet helemaal goed meer werkt. http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
11-23-2009, 03:36 PM
Post: #246
my engine fuse box is the same although I have the AFM version of the engine...
AE86 ex-daily |
11-23-2009, 05:05 PM
Post: #247
do you have a spark?
Ron |
11-23-2009, 08:05 PM
Post: #248
r.hellenbrand Wrote:do you have a spark? I did have spark, didn't test it after swapping some stuff over but the results where the same. Its still weird why I miss my engine check light Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-23-2009, 08:56 PM
Post: #249
heb je ook stroom op je injectoren?want bij mij viel die weg als ik de auto wou starten.er was een verschil(van zenki naar kouki) in de voorste kabelboom waar ook de koplampen op aangesloten zitten
Yaris 1.3 xp9 Yaris 1.0 p1 Mercedes citan weekend driver 1985 AE86 |
11-23-2009, 10:11 PM
Post: #250
alright I've did some pondering and testing:
Pic1: is normal operation Pic2: I pulled the 'EFI Main' - the engine check light doesn't illuminate Pic3: injector fuse thingy I couldn't see on your pics Pic4: overview on how it looks on mine now the 'Engine Main' in the fusebox does feck all - the engine starts also even with it unplugged... and as mentioned above when I unplug the EFI Main my engine check light doesn't illuminate either and the engine will crank (starter works) but not run, just like yours so you might want to check that. also you seem to have other stuff plugs sensors around that area I don't have comparing your pictures with mine so I'm not sure (see pic 3 and 4) Hope that helps and good luck - as mentioned before if you need anything else let me know I'm glad to help ![]() ![]() PS: might wanna add me on MSN and/or Skype if you have that AE86 ex-daily |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 16,428 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 170,963 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 774,960 |
8a9 blue gt coupe | McGlinchey | 8 | 10,488 |
06-22-2016 02:19 PM Last Post: McGlinchey |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 42,936 |
04-07-2016 12:15 PM Last Post: mad.matt |
