11-17-2009, 08:03 PM
Post: #231
you've even copied the tyres
keep up the good work Yaris 1.3 xp9 Yaris 1.0 p1 Mercedes citan weekend driver 1985 AE86 |
11-18-2009, 09:02 PM
Post: #232
Today I recieved the solution to my OBX exhaust problem
11-18-2009, 09:08 PM
Post: #233
looking good although I personaly prefer the spring type solution for better airflow and less turbulences, like this
![]() but as you had to get a new piece in there certainly not a bad choice
AE86 ex-daily |
11-23-2009, 12:10 AM
Post: #234
Well got my OBX exhaust completly installed now.
And Ivan came to help me the whole Saturday. To bad we didn't got the car running due to a couple of downsides. - empty battery - mysterious electronic problem - grounding problem So on Sunday I went out for another try. This time Aram was so friendly to come along. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-23-2009, 12:14 AM
Post: #235
now the problem.
Engine does crank and fuel pump is running but I am missing the engine check light during ignition key on first spot. Seems there is no connection between the ecu and the rest of the engine. I made a movie from it. Hope someone can help me. Becaus I am running out of ideas why its not working.[/video] Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-23-2009, 12:33 AM
Post: #236
the sound in the ed after you turn the key again sounds just like when i had a shortcut in the light switch - probably not much of a help but it's defo the same sound (was apparent when the pin for the cluster had juice on without the lights themself)
I see you attached an additional ground - is the original ground that goes on to the intake plenum (thick wire where the injectors are) also attached? AE86 ex-daily |
11-23-2009, 08:55 AM
Post: #237
We had the plenum ground connected on saturday, looks like robo moved it to the chassis.. didnt fix the problem.
11-23-2009, 10:24 AM
Post: #238
Maybe You changed battery terminals? Check it.
11-23-2009, 11:47 AM
Post: #239
Thank you for your suggestion, but that I'm 100% certain we did that right.
11-23-2009, 12:16 PM
Post: #240
due to the busing sound at the end I guess some wireing got shorted or similar... I don't have a garage anymore to test things out as I just moved to Brussel but have a look with a current tester in the area of the drivers footwell... maybe you can locate the bussing sound and go from there
I'm not 100% sure but the sound seems to be for shortcircuited relay and switches in general... not just the light. EDIT: don't guess you have the day off on a Monday or Wednesday? I could come and have a look... AE86 ex-daily |
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 19,451 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 192,569 |
| Aram's 3SGE Beams Levin Coupe | robokill | 665 | 853,986 |
| 8a9 blue gt coupe | McGlinchey | 8 | 11,982 |
06-22-2016 02:19 PM Last Post: McGlinchey |
| Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 48,391 |
04-07-2016 12:15 PM Last Post: mad.matt |
![AEU86 AE86 - Robokill 1984 Levin Coupe 8...new engine [Image: AEU86 AE86 - Robokill 1984 Levin Coupe 8...new engine]](https://www.aeu86.org/download/downside-of-obx/id/12987.jpg)
![AEU86 AE86 - Robokill 1984 Levin Coupe 8...new engine [Image: AEU86 AE86 - Robokill 1984 Levin Coupe 8...new engine]](http://surly.smugmug.com/photos/21682056-L.jpg)
