11-23-2009, 12:40 PM
Post: #241
Lennert,
Try this:
Remove the following fuses:
-STOP
-HEATER (if you have it)
-DOME
-HORN
-RADIO
-EFI
Pull the following relays out:
-DEFOGGER
-TAILLIGHT
-HEADLIGHT
Those are about all of the circuits that are connected to 12V that do not go through the ignition switch.
See if the buzzing stops.. then start plugging them back in one by one until you find the one that causes you problems.
11-23-2009, 12:42 PM
Post: #242
Hey bean, thx for the offer and now I don't have a day off Sad Saterday is my day of wrenching on the hachi.
The sound comes from a relais (sorry didn't tell that sooner) at the fuse box near the clutch pedal. I changed the box over from a spare which I had laying around with other relais (same type but diffrent ones) and didn't help.
For the wierd reaspn. If I plug in an ECU from an AE82GT or from an kouki AE86 I don't get the wierd sound. I don't get an engine checklight either.
I also changed the cluster unit for another one and didn't didn't do much.
My own guess is that I used the wrong engine wireloom. But that seems nearly impossible because the zenki and kouki have diffrent diagnostic plugs.
It might be possible for me to change the inner loom and the engine loom but I need to check my stock. If anyone has a good guess......
11-23-2009, 12:50 PM
Post: #243
I do have an MAP engine loom with me but I wouldn't think this will help a lot... IMHO it's easier to try and find the cause... I'll do some head scratching and see where it leads me (might be able to dublicate your fault on my car... but I brought very little tools so could take a while) Smile let me know any details you find out in the meanwhile.
IMHO the box that does the sound isn't the one at fault but another one, remotely connected to it...
11-23-2009, 02:31 PM
Post: #244
could you check your engine fuse box ? is it the same as mine ? I can replace that one.
11-23-2009, 03:07 PM
Post: #245
ik heb bijna het zelfde probleem gehad.
het lag bij mij aan een kapotte zekering + een contact slot wat niet helemaal goed meer werkt.
http://bruutt.blogspot.nl/
11-23-2009, 03:36 PM
Post: #246
my engine fuse box is the same although I have the AFM version of the engine...
11-23-2009, 05:05 PM
Post: #247
do you have a spark?
Ron
11-23-2009, 08:05 PM
Post: #248
r.hellenbrand Wrote:do you have a spark?
Ron
I did have spark, didn't test it after swapping some stuff over but the results where the same. Its still weird why I miss my engine check light
11-23-2009, 08:56 PM
Post: #249
heb je ook stroom op je injectoren?want bij mij viel die weg als ik de auto wou starten.er was een verschil(van zenki naar kouki) in de voorste kabelboom waar ook de koplampen op aangesloten zitten
Yaris 1.3 xp9
Yaris 1.0 p1
Mercedes citan
weekend driver 1985 AE86
11-23-2009, 10:11 PM
Post: #250
alright I've did some pondering and testing:
Pic1: is normal operation
Pic2: I pulled the 'EFI Main' - the engine check light doesn't illuminate
Pic3: injector fuse thingy I couldn't see on your pics
Pic4: overview on how it looks on mine
now the 'Engine Main' in the fusebox does feck all - the engine starts also even with it unplugged...
and as mentioned above when I unplug the EFI Main my engine check light doesn't illuminate either and the engine will crank (starter works) but not run, just like yours so you might want to check that.
also you seem to have other stuff plugs sensors around that area I don't have comparing your pictures with mine so I'm not sure (see pic 3 and 4)
Hope that helps and good luck - as mentioned before if you need anything else let me know I'm glad to help Smile - just not on the weekend that is still reserved for my wife as we are still new in this country and I don't wanna live her bored home alone yet Wink
PS: might wanna add me on MSN and/or Skype if you have that
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 16,421 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 170,829 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 774,171 09-03-2017 09:24 PM
  8a9 blue gt coupe McGlinchey 8 10,479 06-22-2016 02:19 PM
Last Post: McGlinchey
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 42,924 04-07-2016 12:15 PM
