Proportioning valve
01-08-2009, 11:28 PM
Proportioning valve
Can anyone tell me where to find the brake proportioning valve and tell me what it looks like, I think mine might be missing
Thanks TC An analogue brain in a digital World |
01-09-2009, 12:44 AM
Proportioning valve
It's a metal thingy on the inner fender (wheel well), close to the brake master cilinder. You should be able to follow the brakelines from the master cilinder to the valve.
01-09-2009, 01:10 AM
Proportioning valve
you can see it in the middle of the pic, where the 2 brakelines from the master run into!
01-09-2009, 01:12 AM
Proportioning valve
Thanks Ivan, I have had a look and the rear brake pipe goes straight from the master cylinder to the rear brakes and the front brake pipe goes from the master cylinder into a 'T' piece and then on to the front brakes. I guess the valve should be in the rear brake line ?
01-09-2009, 01:18 AM
Proportioning valve
Ok definately not there then
Good thing I fitted a bias valve in line to the rear brakes. I could still use some more rear bias though (rally car) any ideas other than an adjustable pedal box ?
01-09-2009, 01:19 AM
Proportioning valve
i don't need this setup, so you can have the valve from me if you want?
don't know if there are any moving parts in there, because it's in my shed for at least 4 years allready
02-07-2009, 08:04 AM
Proportioning valve
What? No proportioning valve? I guess you'd still have stoppers. Maybe? I dunno. Soak that rusty thing in WD40 for a week and then spray air through it; good-as-gnu!
Jason Clark JC Atlanta, GA 1984 AE86 SR5 Coupe 1987 MA70 (60-1,.70A/R; AEM EMS) 1994 Honda Accord EX |
| 4A-GE valve shim disintegrated | DaLanZhu | 2 | 3,272 |
04-30-2025 12:54 PM Last Post: DaLanZhu |
| 4AGE Valve Buckets Scored | Steller Engineering | 2 | 3,201 |
| 20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 4,349 |
| HKS valve springs | totta Crolla | 3 | 4,967 |
| Valve clearance | leon205gti | 7 | 12,349 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
