Project SE82 (3S-GE powered AE82)
11-21-2005, 06:11 PM
I have been wanting to do this (building a racecar out of an old corolla) for many years, but I always thouth it was for "those other guys". About a year ago I got to thinking.. Why couldn't I do this as well as anybody else? I only have one life, so why not live it now, right?
So... I'm not going to bore you with all the stories about the project that you are not interested in and I have forgotten half of. Instead I'll go right to the essentials.
Origin:
1985 Toyota corolla 1.6 DX
4A-C powered front-wheel-drive granny transporter
[Image: AEU86 AE86 - Project SE82 (3S-GE powered AE82)]
Engine:
2nd Generation 3SGE from a 1991 Celica GTi
Suspension:
Not really sure yet what the combination of corolla/celica parts I will use but the Celica parts will (probably) be from the generation previous to the engine donor because of the difference in availability (and price Smile ).
Although I am a bit curious about one of those DIY Coilover kits available on EBAY.
Brakes:
I will most certainly use a complete stock ST162 brake system.
Using: -98 Camry 3.0 V6
Abusing : -85 Corolla 2.0 GTi
11-21-2005, 06:41 PM
Yeah post pics and info! Sounds like a lot of funSmile
11-21-2005, 11:12 PM
Ofcourse it can be drifted!!! Full reverse drift! >Smile
No, we actually had a discussion about this. It would be possible to start a FWD to drift, but not sustain the drift. But that is a too long discussion to start over here... Wink
Show us the pics!!!! Hurray![/list]
11-22-2005, 03:15 AM
(I have removed the question in the first post. One of you moderators can remove your answers if you like.)
Allrightythen Smile I guess you want to see some pics.
This is the poor excuse for an engine that was there before:
The front and rear tranny mounts bolts almost right up to the S-53 tranny.. The front one needed to be moved a little bit to the right for the engine to point straight. The left and right mount couldn't be used at all since they weren't only in the wrong places. They were also too narrow.
So I cut them off, along with the battery plate. The battery will be moved to the trunk anyway.
Testfitted the new engine:
The right engine mount. As you can see it wouldn't have fit at all.
Really dirty tranny.. This mount needed to be moved a little bit forwards.
Begun working on the left tranny mount. Cutting that 4mm steel plate with a 3mm cutting disc on the angle grinder is hard work:
Also removed the tank because it needs to be converted to EFI..
As you all can see, there is still A LOT to be done.. Smile
Not as fun to work on it now as it was in the summer though.. Had about 7 degrees C in the garage today.. Sad
So what do you think? Should I keep posting pics? (retorical question Wink )
11-22-2005, 12:06 PM
keep posting this looks interesting Smile
11-24-2005, 12:28 AM
yeh look interesting keep us updated Thumbs up!
11-24-2005, 12:06 PM
Isn't that an AE80? The AE82 is a hatchback I guess!
Best regards
11-24-2005, 01:42 PM
are you planning on turboing the 3s? would make a killer sleeper. Wink
11-24-2005, 02:03 PM
yep man keep those pic and progress posted, really interested in seening how this goes!
11-24-2005, 05:31 PM
Apolan Wrote:are you planning on turboing the 3s? would make a killer sleeper. Wink
~160hp and ~900kg will make it a sleeper anyway.. Smile
Plus, swedish laws make it impossible for me to get it legal if I turbo it.
But you never know.. Wink
  NZ AE85 - soon to be BEAMS powered Hachi Go 46 82,659 06-24-2011 10:12 PM
Last Post: [Walaki]D`Lair
  X-TURBO ae82 5dr, the daily badass Lajoosh 13 22,430 09-25-2010 09:24 PM
Last Post: Lajoosh
  The MCNSPORT.com RE86 - Rotary Powered AE86.. MCNSPORT.com 19 33,012 10-08-2009 08:56 PM
Last Post: MCNSPORT.com
  4AGE Powered 1972 MG Midget byd1380 7 18,432 04-25-2009 04:12 PM
Last Post: Garry Mckenzie
  Rotachi 13BT powered by Jarda [CZ] SekiguchiUeno 1 6,088 04-24-2008 10:17 PM
Last Post: SekiguchiUeno
